Jul 3, 2010 - 6:39 PM
Enthusiast ![]() Joined Apr 22, '08 Currently Offline Reputation: 2 (100%) |
How do you remove/ replace alternator belt ( 7AFE)? do i need to remove the pully of the alternator? or remove the alternator?
Help please , Thanks This post has been edited by rheyx: Jul 3, 2010 - 6:52 PM |
Jul 3, 2010 - 6:55 PM
Enthusiast Joined Jun 27, '10 From New York, NY Currently Offline Reputation: 0 (0%) |
I think you're talking about the Serpentine Belt....
On the front of the alternator there is a tension adjustment bolt. Loosen that until the belt clears the pulley so that you can remove it. You don't have to remove the tension bolt, just loosen it. |
Oct 15, 2010 - 3:09 AM
Enthusiast Joined Oct 14, '10 From hawaii Currently Offline Reputation: 0 (0%) |
I think you're talking about the Serpentine Belt.... On the front of the alternator there is a tension adjustment bolt. Loosen that until the belt clears the pulley so that you can remove it. You don't have to remove the tension bolt, just loosen it. do you know what the belt called just below that one? and how do you change it? |
Oct 19, 2010 - 8:06 AM
Enthusiast ![]() Joined Feb 21, '10 From Elizabethtown, KY Currently Offline Reputation: 0 (0%) |
I think you're talking about the Serpentine Belt.... On the front of the alternator there is a tension adjustment bolt. Loosen that until the belt clears the pulley so that you can remove it. You don't have to remove the tension bolt, just loosen it. You wouldn't happen to know how tight it should be upon replacing the belt would you? -------------------- HONDA
Hold On Not Done Accelerating |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 10:18 AM |
