> Indash dvd player
post Jul 10, 2010 - 2:07 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
does any1 have a write up on how to install a indash dvd into a 6gc
I only want to be faster than the guy next to me.
post Jul 11, 2010 - 12:18 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
It's really simple:
-twist off shift nob
-carefully pull of the trim surrounding the shifter
- pull off the trim around the radio. Its a little tricky but don't be scared to give it a good pull.
next just remove the screws holding in stock radio.
It should be two units, I believe its a cd player and then the radio. The two are held together by a a bracket.
So unbolt the bracket and then you have to put the bracket on to your new screen (assuming its a double din screen not a flip.)
Wire in the harness and your basically set to go. You can bolt the brackets into the car and then put all the trim pieces back in.
I hope that makes at least a little bit of sense, If you need a hand let me know, I've had mine in and out numerous times.
My Celica!
post Jul 11, 2010 - 6:36 AM
Smiley
Joined Jul 28, '09
From Christchurch, New Zealand
if its a 7 inch dvd one like mine you may need to do some minor modifcation to the surround as the plastic hole may be slightly to small id recomend using a dremal tool but it can be done with a normal drill if you take your time although will not be as neat smile.gif
Lo-Fi Version Time is now: July 28th, 2026 - 5:00 PM
