Jul 12, 2010 - 11:34 PM
Enthusiast ![]() Joined Jul 28, '09 From Christchurch, New Zealand Currently Offline Reputation: 1 (100%) |
so i wired in my new headunit but some of the functions like tv and what not dont work while the headunit thinks the car is moving so where is the cable that says that the handbrake is on and could i connect it to just a constant 12v line so it thinks that is always on or would that not work?? any help greatly appreciated thanks
Jul 13, 2010 - 1:08 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
Splice the E Brake wire into your ground wire ( black ) and it should over ride it here you can play movies with out the E Brake up. Or you can buy a over ride switch connect the green one for video to the black wire and then the red one on the switch to your power supply to your deck. Then just flip it on or off when you want it. It's alot easier.
Jul 13, 2010 - 1:30 AM
ill try just splicing it to the ground cus i got cnfused with the other stuff lol
Jul 13, 2010 - 1:41 AM
It should work, just depends in what type of headunit you have. If it doesn't you can just stop at a audio store and get a over ride switch I'm sure they can explain it easier takes a few minutes and cost like 5$
Jul 13, 2010 - 1:55 AM
i will put it to the test tomoroow thanks
Jul 31, 2010 - 2:46 AM
Enthusiast Joined Nov 5, '09 From Nashville Currently Offline Reputation: 0 (0%) |
if u simply ground the wire to the small bar that is directly behind the radio it will work perfectly u dont need the override switch.
thats how i have mine set up and it works perfectly No problems at all |
Aug 1, 2010 - 10:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
i thought you're suppose to wire it up to the hot wire (positive)....not the ground. cause if you ground it, it won't have a current going to it
Aug 1, 2010 - 11:36 PM
na the ground worked thanks for the idea, just need to get a new antenna and then a splitter so i can pick up some channels
Aug 1, 2010 - 11:44 PM
i do have an antenna from the car im parting out, I'll have to see if it works though cause it's half sticking out right now
Aug 3, 2010 - 12:31 AM
might cost me more just to ship it than what its worth since im in NZ lol
| Lo-Fi Version | Time is now: August 28th, 2026 - 11:09 PM |
