> ABS light is on, tried pulling the abs code, NEED HELP PLEASE!
post Jul 15, 2010 - 2:01 PM
barterj
Joined Aug 28, '08
From Woolwich, Maine
i fallowed a how to i found telling me to bridge the Tc and E1 ports and do the same thing as reading and engine code except its off the abs light. This is what happens.
When i turn the key the abs is illuminated, it goes out for second and then comes back on and stays on, its doesn't repeat. So i read something that says if the abs light stays on it could be a faulty abs computer. I went to the scrap yard and found 2 more and tried them both and the same thing happened. I can't imagine that both abs computers i tried were both faulty as well as mine. the chances of that i assume would be one in a million. any help would be appreciated.
This post has been edited by barterj: Jul 15, 2010 - 6:14 PM
- barterj   ABS light is on, tried pulling the abs code   Jul 15, 2010 - 2:01 PM
- - Spider77   QUOTE (barterj @ Jul 15, 2010 - 3:01...   Jul 16, 2010 - 3:30 PM
|- - Tech-Nics   QUOTE (Spider77 @ Jul 16, 2010 - 4:3...   Aug 6, 2010 - 2:20 PM
- - barterj   No i didn't pull the short pin out before, i d...   Jul 19, 2010 - 1:35 PM
- - barterj   checked abs sensor or speed sensor, anyway it is a...   Jul 19, 2010 - 6:54 PM
- - Spider77   Well glad that you at least know what is wrong (as...   Jul 19, 2010 - 8:30 PM
- - barterj   Today I got an ABS sensor from a 97 Camry for ...   Jul 20, 2010 - 5:09 PM
|- - phrax   QUOTE (barterj @ Jul 20, 2010 - 5:09...   Aug 6, 2010 - 3:06 AM
|- - phrax   QUOTE (phrax @ Aug 6, 2010 - 4:06 AM...   Aug 24, 2010 - 12:41 PM
|- - phrax   QUOTE (phrax @ Aug 6, 2010 - 4:06 AM...   Jul 18, 2011 - 1:08 AM
- - Spider77   No problem, glad everything worked out for you.   Jul 20, 2010 - 5:19 PM
- - Spider77   The diagnostic box is pretty much what it is. I g...   Aug 6, 2010 - 3:04 PM
- - mkernz22   what's the easiest way to remove the sensor if...   Aug 24, 2010 - 12:56 PM
- - barterj   Probably a pair of pliers. if pliers won't wor...   Aug 30, 2010 - 4:09 PM
- - mkernz22   fffff thattt, i think it would be easier to replac...   Aug 30, 2010 - 7:35 PM
- - supercoolee   my abs light turns on and stays on every once in a...   Mar 31, 2011 - 5:55 PM
- - opie_7afe   supercool right between drivers side firewall and ...   Apr 1, 2011 - 3:13 PM
|- - Spider77   QUOTE (opie_7afe @ Apr 1, 2011 - 4:1...   Apr 1, 2011 - 4:51 PM
- - opie_7afe   i really havent a clue man just throwing these cod...   Apr 1, 2011 - 5:02 PM
- - azian_advanced   have you tried clearing the codes and see if the a...   Apr 1, 2011 - 5:30 PM
- - Spider77   You may have braking problems, but when is the las...   Apr 1, 2011 - 5:32 PM
- - opie_7afe   braking problems i dont really have last week some...   Apr 1, 2011 - 6:10 PM
- - Spider77   I think someone else awhile ago had a similar prob...   Apr 1, 2011 - 7:22 PM
- - opie_7afe   well i do know this thing was sitting for a little...   Apr 1, 2011 - 7:38 PM
- - Spider77   Well, if you want to eliminate the connections, ge...   Apr 1, 2011 - 7:49 PM
Lo-Fi Version Time is now: August 25th, 2026 - 2:57 PM
