> Starter replacement help!, im going outta town in 1 day!
post Aug 2, 2010 - 10:19 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
I need to replace my starter.. i tried searching for a how to, or a link of someone else doing it, but couldnt find anything.
can someone tell me how long of a job it is? I got a spare one on another motor thats out of a car, so taking that off shouldn't be too hard, but what about putting it on to my current car..
any help or links or suggestions would be great!
post Aug 2, 2010 - 10:30 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
-disconnect the battey and get it out of your way
-look at the starter and figure out what needs to be moved
-search for bolts, nuts, etc. that are holding the starter
-there should be the grounding cable
-the connecter thingy
-the 2 main bolts that hold the starter
-and it should pull right out
post Aug 2, 2010 - 10:35 PM
mgnt232
Joined Mar 16, '09
yeah disconnect the battery first!
Its not too hard of a job (i did mine like a month ago) although the bolts are in pretty hard places.
You will need to jack the car up because its easiest to get the bolts from under the car.
You then just need to remove the bolt on the cable running to the starter, and the little connector thingy (these can be a pain, but a little help from mr. screwdriver should do the trick)
Then I believe there are just two larger bolts (they are in annoying spots), just loosen those up, and make sure you get a hold of it good, because its heavier than you might expect and comes down fast if you dont hold on lol.
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Aug 2, 2010 - 10:47 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
post Aug 2, 2010 - 11:03 PM
krom8
Joined Jun 17, '10
From Frankfort Kentucky
Get a good worklight. It not a hard job but it's in a frustrating location.
post Aug 2, 2010 - 11:06 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
yeah im getting all the info i can.. cause its already dark as hell here.
so imma wake up early and do it
i got a fat ass party to go to in shaver lake tomorrow night! 6000 feet elevation.. im so stoked
post Aug 3, 2010 - 12:02 AM
ChfNix
Joined Aug 12, '09
From Orange Beach, Alabama
Ya, do it from the bottom! I did mine a couple weeks ago from the top side and it was a PITA! But I didn't have a jack at the time so I had no choice!
Failing to prepare is preparing to fail!
post Aug 3, 2010 - 3:22 AM
Hanyo
Joined Aug 16, '03
From Bay area
you got an ST, you have plenty of room to remove the starter.
On our celicas is easy as to take off. 3 bolts in total to remove and one clip on wire. I ended up laying on top of my strut bars and reached down to remove the two large bolts.
Lo-Fi Version Time is now: August 31st, 2026 - 5:36 AM
