> Feeler: Completely Customized Headlights, Many many details inside, please read thoroughly!
Would you be interested in being able to customize your headlights?
Total Votes: 118
Guests cannot vote
post Aug 3, 2010 - 11:05 PM
Espo
Joined Aug 11, '09
From Buffalo, NY
If you answer "No" to the first poll, please tell me why! With your feedback I may be able to improve my service to help meet the needs of more 6GC owners!
Alright so I have a set of broken headlights laying about that I think I'm going to restore and customize very soon. It wouldn't be very hard to do as I envision it since all I need to do is remove the glass and buy new glass, carve it with a dremel and all that and put it back in.
This lead me and a couple friends to thinking that if we can do it with my headlights (these would be the test batch) then we can do it for other people - offering perhaps the first fully custom 6GC headlight designs ever. The inspiration behind this is CinCity Designs, by the way - I have a feeling Celica headlights will be much easier than 350Z and G37 tails though.
So to get to the point, with sufficient interest I'd think about offering everyone the service here first, then branching out to perhaps EBay and whatnot, assuming all goes well. So to get down to the nitty gritty, let me explain the choices of the poll:
  1. Blacked Out Headlights: Nightshaded lenses (Clear or stock) with black (possibly reflective, will have to look into that) interior housing. May or may not require projector retrofit.
  2. Clear Lenses: Crystal Clear lenses installed, just like the JDM Projectors, only custom made to order.
  3. Stock Lenses: US Style lenses, if you wanted them.
  4. Projectors: Retrofitted projectors from an LHD vehicle, eliminating the need for an LHD conversion on JDM Projectors.
  5. Angel Eyes: Projectors with a custom made halo around them (Could be LED or Electroluminescent Wire) in various colors (illegal colors would be able to be switched off) much like BMW headlights.
  6. "Night Rider" LED Strips: This one's a big if, because I'm not sure if I can make the leds light up in sequence - fairly sure I have timer chips that will allow me to do it, but it would be an experiment first. Basically, I would either install a Night Rider strip in your headlight, or replace the headlight rubbers with one, also coming with an on/off switch. Headlight rubber replacement would be weatherproof.
  7. Halo Turn Signals: Placement of your choice (my idea has them on the outside edge of the lens, inside the glass) that would be a turn signal inside your headlight - wired into your turn signals, and blinks with them. Likely made from EL Wire, or LEDs.
  8. Color-Matched Headlights: Have the inside of your headlights painted to match the color of your car, just like GM does with the Corvette. Would only be available with projector retrofit.
  9. Metallic Colors: Color-Matched headlights with metallic clearcoat - might make it possible to remove the need for a projector retrofit.
  10. Custom Designs: You tell us what you want if you have an idea, we do it for you!
Pricing is to be figured out after we gauge interest - if sufficient interest shows, we'll figure out pricing and go from there. High beams are also an option, so it's not just low beams.
I do know however that there are two ways of doing this - either you can send us a set of your headlights, or you place an order and we order headlights for you - the latter way however would incur a core charge and be much, much more expensive.
Also, you can mix and match any of the choices you like in order to create your own unique 6GC headlights - just as long as they don't negate each other (I.E. Blacked out headlights with a colored interior - duh, lol)
Feedback, support and comments are much appreciated - I'm rather excited about this idea myself!
This post has been edited by Espo: Aug 3, 2010 - 11:33 PM
- Espo   Feeler: Completely Customized Headlights   Aug 3, 2010 - 11:05 PM
- - chacha   if black out means black housing...yes...gotta get...   Aug 3, 2010 - 11:14 PM
- - Espo   ^Edited my post, explaining everything.   Aug 3, 2010 - 11:25 PM
- - mgnt232   great ideas! hope it all turns out well ive ...   Aug 3, 2010 - 11:30 PM
|- - Espo   QUOTE (mgnt232 @ Aug 4, 2010 - 12:30...   Aug 3, 2010 - 11:34 PM
- - yellowchinaman   I'd pay for this service however will they sti...   Aug 4, 2010 - 1:50 AM
|- - Espo   QUOTE (yellowchinaman @ Aug 4, 2010 - 2...   Aug 4, 2010 - 3:01 PM
- - 2bcelica   Very interested   Aug 4, 2010 - 9:07 AM
|- - Spider77   QUOTE (2bcelica @ Aug 4, 2010 - 9:07...   Aug 4, 2010 - 4:43 PM
- - yellowchinaman   great. count me in. even if this doesnt go ahead, ...   Aug 4, 2010 - 3:16 PM
- - JuMPiiN   Throw me on that list ! im in for some Angel E...   Aug 4, 2010 - 3:47 PM
- - cyberblader1130   If i have the money by the time this order goes th...   Aug 4, 2010 - 4:36 PM
- - chacha   1. Chacha (high and lows: White chrome (white to m...   Aug 5, 2010 - 1:42 AM
- - JuMPiiN   If it mattered id pick up some low beams from the ...   Aug 5, 2010 - 2:02 AM
- - thisguy18   i would need to know how much simple projectors li...   Aug 5, 2010 - 2:28 AM
- - Espo   For those of you inquiring about angel eyes, all w...   Aug 5, 2010 - 11:19 PM
- - JuMPiiN   I can pick up some low beams and ship them out to ...   Aug 5, 2010 - 11:42 PM
- - zonz540   I have some integra projectors id be willing to se...   Aug 6, 2010 - 1:45 AM
- - Espo   $Jumpiin: Likely not more than $75. @Zo...   Aug 7, 2010 - 11:46 PM
- - stl95celica   im excited too see what they look like!!   Aug 8, 2010 - 2:01 AM
- - MGCustoms325   Put me on that list. Down for clear lenses, projec...   Aug 8, 2010 - 8:01 PM
- - CelicaRacer97   clear lenses or perhaps the blackout ones would be...   Aug 8, 2010 - 8:31 PM
- - Espo   PMs responded to - please understand I am not taki...   Aug 9, 2010 - 11:57 PM
- - MGCustoms325   Sounds good man. Whats the eta on the test batch? ...   Aug 10, 2010 - 12:01 AM
- - georgie   I'm down for a set of projector lows + black p...   Aug 10, 2010 - 4:04 PM
- - Espo   QUOTE (MGCustoms325 @ Aug 10, 2010 - 1...   Aug 10, 2010 - 9:42 PM
- - MGCustoms325   Well if you need a set of headlights I will get so...   Aug 10, 2010 - 9:54 PM
- - Espo   Nope I have a set - one of them is broken actually...   Aug 10, 2010 - 10:33 PM
- - JuMPiiN   Dude like i said im down to send you a extra set ...   Aug 10, 2010 - 10:35 PM
- - chode   im down too i want to see how it look   Aug 10, 2010 - 11:30 PM
- - richee3   My suggestion for doing projector retrofits in the...   Aug 10, 2010 - 11:39 PM
|- - richee3   QUOTE (richee3 @ Aug 10, 2010 - 11:3...   Aug 26, 2010 - 10:25 AM
- - Espo   @Richee: I'll look into it definitely. I won...   Aug 14, 2010 - 12:25 PM
- - JuMPiiN   Out of curiousity, the headlights would be plug an...   Aug 14, 2010 - 1:20 PM
- - Espo   Yes, direct bolt on - if you choose projectors the...   Aug 14, 2010 - 1:35 PM
- - JuMPiiN   Well whe n you get into it let me know. I have a e...   Aug 14, 2010 - 1:47 PM
- - CELL_PROTOTYPE_X   I'm very interested but would like to see a fi...   Aug 14, 2010 - 2:30 PM
|- - cheela   QUOTE (CELL_PROTOTYPE_X @ Aug 14, 2010 ...   Aug 14, 2010 - 3:04 PM
- - Bigblock   Good ideas, & good luck!! So since I ...   Aug 14, 2010 - 3:05 PM
|- - Espo   QUOTE (Bigblock @ Aug 14, 2010 - 4:0...   Aug 17, 2010 - 3:51 PM
- - MGCustoms325   Thanks for the update. Good luck on that search. K...   Aug 17, 2010 - 3:59 PM
- - RayLee   Interested in Clear Lenses! if u ever get this...   Aug 26, 2010 - 9:30 AM
- - SwissFerdi   Would it be possible to do a projector/angel eyes/...   Aug 26, 2010 - 10:02 AM
- - snakeloa   I would buy a set of these   Aug 30, 2010 - 6:18 PM
- - georgie   any news?   Sep 13, 2010 - 3:28 PM
- - CelicaRacer97   so whats the news on this??? i just want regular h...   Sep 14, 2010 - 3:44 AM
- - TEAMFaint   QUOTE (richee3 @ Aug 26, 2010 - 10:2...   Sep 14, 2010 - 9:23 PM
- - OOBE   LOL!   Sep 14, 2010 - 9:26 PM
- - REIDO   very interested can't wait to see some finishe...   Sep 24, 2010 - 8:20 PM
- - easternpiro1   any breakthru yet?   Oct 13, 2010 - 3:07 AM
- - DEATH   I have to vote no unless the price is seriously lo...   Oct 13, 2010 - 3:23 PM
- - Espo   Hey guys, I know it's been a while. My exhaus...   Oct 21, 2010 - 1:49 PM
- - 95celicastLSR   count me in for some low beam projectors with or w...   Oct 22, 2010 - 9:51 PM
- - georgie   glad to hear things are lookin on the up & up ...   Oct 24, 2010 - 11:28 PM
- - 95celicastLSR   update ....??   Dec 9, 2010 - 7:26 PM
- - MGCustoms325   Is this still going to happen?   Feb 27, 2011 - 5:48 PM
- - Bigstring   Last active 3 months ago QUOTE (MGCustoms325 ...   Feb 28, 2011 - 10:04 AM
Lo-Fi Version Time is now: June 23rd, 2026 - 7:22 AM
