Aug 4, 2010 - 8:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I've seen people routing them in front of the exhaust manifold and down, but I was thinking of routing it down the hole where the resonator was and having the filter there right inside the fender. Keep in mind, I'll be adding an AEM air bypass valve somewhere in the line.
June '12 COTM '95 AT200 |
Aug 4, 2010 - 9:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
dat is best!
Aug 4, 2010 - 9:06 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
isnt the resonator on the exhaust? The actual "best way" is a bunch of complicated math equations (i posted about this before), and with an ST you really wont get much power gains.
but just do what you want, obviously keep it away from heat, and still be carefull where it ends up lol even with the bypass. Heres what i did with mine Sorry bad pic, but it continues down there ![]() -------------------- |
Aug 4, 2010 - 9:08 PM
isnt the resonator on the exhaust? The actual "best way" is a bunch of complicated math equations (i posted about this before), and with an ST you really wont get much power gains. but just do what you want, obviously keep it away from heat, and still be carefull where it ends up lol even with the bypass. Heres what i did with mine Sorry bad pic, but it continues down there ![]() That hole you're referring to is the one I'm talking about. The stock intake box had a resonator. That weird looking random box behind your turn signal on the LH side. -------------------- taking too long to mod since '09
Aug 4, 2010 - 11:10 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
here is what i did, to draw more cold air in i took and ran hosing throught the old air box hole and down into the fender right under the turn signal with a velocity stack there. you can see the hose running right under the fuze box.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Aug 5, 2010 - 12:15 AM
wow thats pretty cool lol. is your strut bar, turned? was it too high? mine is and i had to cut out of my old hood, but mt new CF hood i dont want to cut out of, do most bars turn like that?
Aug 5, 2010 - 1:39 AM
here is what i did, to draw more cold air in i took and ran hosing throught the old air box hole and down into the fender right under the turn signal with a velocity stack there. you can see the hose running right under the fuze box. ![]() Do you feel any difference? -------------------- taking too long to mod since '09
Aug 5, 2010 - 8:18 AM
from the cai or the strut bar, because now the bar is flat, i had to do some mods, but i had no hood clearance problemes. in the heat the hose feels like it helps.
Aug 5, 2010 - 10:27 PM
Enthusiast ![]() ![]() Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
I've seen people routing them in front of the exhaust manifold and down, but I was thinking of routing it down the hole where the resonator was and having the filter there right inside the fender. Keep in mind, I'll be adding an AEM air bypass valve somewhere in the line. I've actually had mine routed both ways. Currently I have it routed under the fuse box into the fender. Originally I had it come out around the block behind the rad in front of the header and then down. My filter actually rested on the plastic piece under the car. I'll tell you I didn't really notice a difference between that and when I routed it inside the fender. I changed it due to fear of sucking in water and even though i've got it in the fender I still put a bypass valve on it. I'd recommend putting it in fender, its safer and you won't really gain anything from routing where the header is. That "resonator" for the intake was a pain to get out though. For me anyway.... -------------------- ![]() |
Aug 6, 2010 - 12:21 AM
I've seen people routing them in front of the exhaust manifold and down, but I was thinking of routing it down the hole where the resonator was and having the filter there right inside the fender. Keep in mind, I'll be adding an AEM air bypass valve somewhere in the line. I've actually had mine routed both ways. Currently I have it routed under the fuse box into the fender. Originally I had it come out around the block behind the rad in front of the header and then down. My filter actually rested on the plastic piece under the car. I'll tell you I didn't really notice a difference between that and when I routed it inside the fender. I changed it due to fear of sucking in water and even though i've got it in the fender I still put a bypass valve on it. I'd recommend putting it in fender, its safer and you won't really gain anything from routing where the header is. That "resonator" for the intake was a pain to get out though. For me anyway.... Yeah it was a pain for me too. If I had taken off the fender, it would've been easier... but I didn't wanna do that lol. -------------------- taking too long to mod since '09
| Lo-Fi Version | Time is now: August 29th, 2026 - 9:48 PM |
