> 7A-FTE Project, Missing anything? Any comments?
post Aug 9, 2010 - 12:50 AM
zonz540
Joined Jul 3, '09
From UT
Im about half way done getting the stuff i need to turbo my 7A. As for the additional stuff not on the spreadsheet, i do know ill need a patch harness and a 2 Bar MAP sensor of some kind. (Ive been told my F/IC can do this in lieu?).
So far, heres the list. Any comments or suggestions are welcome. Let me know if im missing anything.
post Aug 9, 2010 - 1:11 AM
Johnnyny
Joined Apr 28, '09
From York pa
2 bar map sensor from an all trac works best
post Aug 9, 2010 - 1:33 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
eBay ftmfw, I want to see this setup and i would like to see the numbers you get. GL with your build ill be watching this closely !
post Aug 9, 2010 - 4:12 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
the FIC can clamp the factory MAP sensor, thats what im doing right now on my setup.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 10, 2010 - 2:04 AM
zonz540
Joined Jul 3, '09
From UT
Ive heard about this "clamping" thing. What does it mean? The factory MAP functions until it hits boost and the FIC takes over?
post Aug 10, 2010 - 10:11 AM
celica74
Joined Feb 8, '10
From North Carolina
For me, the 4afe turbo manifold (bottom mount) didnt work. Has to be shortened which is alot of work. I bought a custom 7afe turbo manifold (bottom mount) which is alot shorter so it holds the turbo up alot more, and the radiator is in the way. I dont know if i should get a civic radiator, or mod the manifold i just got. If you find a way to work the 4afe manifold let us know.
post Aug 10, 2010 - 10:23 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (celica74 @ Aug 10, 2010 - 8:11 AM) *
or you can just get my 7A-FE manifold. if i were te sell the manifold by itself it would be about 600 with a life time warrenty.
"clamping" the sensor mean this...the FIC uses algorithyms to take the MAP sensor signal and alter it to what the factory ECU sees. so for example, off boost it works normal, but when you start going into boost when the MAP snesor is sending 4V the FIC alters that and sends 2V to the ECU. there is more going on in the background but thats about it.
post Aug 12, 2010 - 1:06 AM
zonz540
Joined Jul 3, '09
From UT
I figured it would do an alteration after boost. Is it easier/more reliable to use my F/IC or just get an alltrac MAP?
post Aug 12, 2010 - 10:08 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
well if you have an FIC already. id say go for it first. i posted my MAPs in another thread. you can use those to get you started but i HIGHLY suggest getting tuned still
Lo-Fi Version Time is now: September 12th, 2026 - 2:17 PM
