Aug 13, 2010 - 12:39 PM
Enthusiast ![]() Joined Mar 20, '10 From uk, essex Currently Offline Reputation: 0 (0%) |
hi every body got aquestion about the celica fueling iam waiting on delivery of a kamakze power deck for my 3sge and am wonderinif any one on here had had one or has one on there acis valve? was concernd about runing to lean and was hoping to get some advice adout it, if you needed to fit a fuel pressure regulator to balence the af ratio ?
the local tuning place to me said id have to go ecu upgrade but if the motor is getting to much air then it follows that more fuel is needed anyway? so has anyone got any advice concerning this modification it may not mater as it might be fine but got ask |
Aug 13, 2010 - 2:41 PM
im having a hard time understanding what you are asking here, what are you installing?
Aug 14, 2010 - 7:58 AM
I'm in stalling a power deck. It's a acis valve spacer on the quad throttle system, ups the air intake in the acis buy quite a bit and I was concernd a out running to lean but the guy thatsold my it says not to worry, so need to hear from those that have used one to see if I need to up my fueling. I was trying to type my original question on my ps3 so my gramma is all over the place!
Aug 14, 2010 - 10:31 AM
do you mean a spacer on the TVIS on the intake manifold? what engine is this? i have never heard of power deck
Aug 14, 2010 - 4:47 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
do you mean a spacer on the TVIS on the intake manifold? what engine is this? i have never heard of power deck ask the people u are buying it from ive never read that u go lean because of it on the 3sge its the acis This post has been edited by Johnnyny: Aug 14, 2010 - 4:48 PM |
Aug 15, 2010 - 1:13 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
no, you wont need to adjust your fuelling.
Aug 15, 2010 - 11:35 AM
Enthusiast ![]() ![]() ![]() Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
Wouldn't the ECU adjust the difference anyway?
-------------------- "God created turbo lag to give V8's a chance"
Aug 17, 2010 - 1:49 AM
Yeah I'm running the 3sge block in mine, rusty helped me reset the acis before when I first got the car and it ran a he'll of a lot better, the only information I've found in these decks is all jus tyre same stuff about upping power or in japanise. So needed impashal advice but a lot of people seem not to have heard of the power deck.
I figured the ecu would adjust the fueling to account for the extra air of course but was wondering if it was out of the regulators and pumps normal peramiters, haven't got the Money for a new engine! It seems as though from most replys that you don't have to worrywhich is good. I'll be power running the car anyway after fitting it just to be sure and if king rusty says so then it good enough for me. Not been wrong yet! |
Aug 17, 2010 - 2:29 AM
easy now with the king rusty stuff
best of luck with the install mate -------------------- |
Aug 17, 2010 - 4:46 PM
Na rusty you've helped me out loads every time I pit up a question the right answer seems to come from you,
It's gonna be a long wait as i have to wait about a month for vince and kamakaze to make the deck and for it to come and a out two minute to fit! Will up date when fitted but if anyone. That has one etc please contioune to answer it all helps! |
| Lo-Fi Version | Time is now: August 31st, 2026 - 11:57 PM |
