Aug 14, 2010 - 10:05 PM
Enthusiast ![]() Joined Mar 4, '09 From Ohio Currently Offline Reputation: 2 (100%) |
Does anyone know if the head gasket sets off ebay are worth buying?..... http://cgi.ebay.com/ebaymotors/93-97-1-8-L...s#ht_3423wt_924
-------------------- Scraps
Aug 14, 2010 - 10:07 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
Just buy a metal one from like Autozone. I got mine for my 5s for $89
Aug 14, 2010 - 10:08 PM
Just buy a metal one from like Autozone. I got mine for my 5s for $89 I'm rebuilding the head.... So I need everything :-/ -------------------- Scraps
Aug 14, 2010 - 10:11 PM
Buy a complete gasket seal kit with a metal head gasket, mine was $350 including the gasket. From ABC auto. not sure if theres one where you live.
Aug 14, 2010 - 10:12 PM
Buy a complete gasket seal kit with a metal head gasket, mine was $350 including the gasket. From ABC auto. not sure if theres one where you live. Never heard of it... The set Advance has is like 120 or somewhere in there. -------------------- Scraps
Aug 14, 2010 - 10:17 PM
Is it for everything tho, mine came with all gaskets, seals, everything. But i did get a oil pump degreaser sealant, and some other things.
Aug 14, 2010 - 10:21 PM
Is it for everything tho, mine came with all gaskets, seals, everything. But i did get a oil pump degreaser sealant, and some other things. 137 my bad everything but the bolts which are almost 60... http://shop.advanceautoparts.com/webapp/wc...S_1419186592___ -------------------- Scraps
Aug 14, 2010 - 10:25 PM
If your doing all that you might as well replace the oil pump, the water pump, and all of those good things.
Aug 14, 2010 - 10:29 PM
If your doing all that you might as well replace the oil pump, the water pump, and all of those good things. The pumps themselves or the gaskets?... The gaskets have already been changed I'm doing a full engine rebuild... The block is done I just have to do the head now... -------------------- Scraps
Aug 14, 2010 - 10:30 PM
I mean while its out you might as well change them all. I changed all of mine. It will live again in 2-3 days. after 5 months.
Aug 14, 2010 - 10:35 PM
I mean while its out you might as well change them all. I changed all of mine. It will live again in 2-3 days. after 5 months. All what, the gaskets? Sorry I'm misreading your post. -------------------- Scraps
Aug 14, 2010 - 10:37 PM
Replace the pumps. like oil pump, and water pump. I mean while the engine is out you might as well your suppose to replace them after like 50-100K anyways thought.
Aug 14, 2010 - 10:43 PM
Replace the pumps. like oil pump, and water pump. I mean while the engine is out you might as well your suppose to replace them after like 50-100K anyways thought. Ya... Advance has them both for 243.... What'd you pay? -------------------- Scraps
Aug 14, 2010 - 10:44 PM
I got the water pump from someone on here for like 50 bucks brand new OEM, and the oil pump was $75. Altogether for everything gaskets, seals, pumps, everything for rebuild i spent about $1500
Aug 14, 2010 - 10:50 PM
I got the water pump from someone on here for like 50 bucks brand new OEM, and the oil pump was $75. Altogether for everything gaskets, seals, pumps, everything for rebuild i spent about $1500 I'm trying to keep down on the price a lil, because I'm trying to save for the 7agte conversion.... I just want it to get me by till then... It was at 300,000 miles and using a quart of oil a day so it couldn't wait.... -------------------- Scraps
Aug 14, 2010 - 10:51 PM
oh wow ! i would def buy new pumps then lol. Just bc of the fact it was at 300K.
Aug 14, 2010 - 10:53 PM
oh wow ! i would def buy new pumps then lol. Just bc of the fact it was at 300K. They're not the origional lol... I'm not sure how many miles are on them though.... -------------------- Scraps
Aug 14, 2010 - 10:56 PM
You should still replace them. If your rebuilding you should. I replaced everything, just a standard OEM rebuild. Even bought timing belt kit and replaced all of that. New harmonic balancer everything.... but back on topic i wouldnt buy from eBay go get it from Toyota or Advance Auto, somewhere from there.
Aug 14, 2010 - 10:57 PM
You should still replace them. If your rebuilding you should. I replaced everything, just a standard OEM rebuild. Even bought timing belt kit and replaced all of that. New harmonic balancer everything.... but back on topic i wouldnt buy from eBay go get it from Toyota or Advance Auto, somewhere from there. K thanks... -------------------- Scraps
Aug 14, 2010 - 10:58 PM
NP i hope i helped lol.
| Lo-Fi Version | Time is now: June 24th, 2026 - 7:46 AM |
