Aug 14, 2010 - 11:49 PM
Enthusiast Joined Aug 10, '10 From TN Currently Offline Reputation: 0 (0%) |
Aug 14, 2010 - 11:54 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
dude there are hundreds of threads on this they fit our engine but are not long enough so u need to extend them
Aug 14, 2010 - 11:58 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
eBay isnt worth it. Welds are s**tty and poor quality. It makes the sound better though.
Aug 16, 2010 - 9:45 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Lol, memories.
I remember when I first joined I did the same thing, and got reamed about using search....which you should =P I have that exact header. Adds a bit of noise to a ST, bit louder at the exhaust end. Hard to hear if you already have a SRI or CAI. ' You can hear your valves clicking like crazy...that is if yours click. Performance changes are certainly there as well. Some good, some bad. 2nd, 3rd opened up a ton nearing the end of the gear. Lost some take off, but that could be specific to my cellie. I assume from loss of back pressure? Only noticable when first taking off, then it breaths much better...throaty as they call it. Edit: You will need to get your downpipe welded to the cat, or some other means. The downpipe also doesn't have the second sensor hole, this does not seem to be a problem if 94-95s, as I've had mine on for well over 5 months and hav't thrown a CEL. I assume with OBDII there is a bit more monitoring on that sensor..? 96+ I'd certainly get that other sensor plugged. This post has been edited by rave2n: Aug 16, 2010 - 9:48 AM |
Aug 16, 2010 - 10:00 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
agreed for the search
I have a 94 and dont have the second o2 sensor hooked up and only throws a code if you are low on fuel and driving...well.. like a dick lol (flooring it) not sure why it does that, but other member have had it as well. as for the fitment...well dont do it your self like i did. I talked to a shop and he told me they couldnt touch it because of the loss of the first cat (so its not technically legal) so i had to do it my self, and its a bit of a pain! The downpipe ends up about a foot away from the cat, so you have to cut somewhere behind the cat and bring it to the downpipe, cut the nub off the downpipe and clamp it on with some exhaust sealant, and then you still need to extend the piping about a foot As far as power, im not sure there is much (technically speaking) but in the higher rpm's it definitely sounds like the gear can go further GL with the install -------------------- |
| Lo-Fi Version | Time is now: September 1st, 2026 - 2:10 AM |
