> 5sgte bogging/hesitating on accel.
post Aug 18, 2010 - 5:35 PM
TurboToys
Joined Mar 9, '05
From Vandalia, Ohio
My friend has a 94 celica gt that we turbo'd about 4 years ago. It had a st165 ct26 setup and map sensor, 7mge injectors, walbro 255 and no intercooler( i keep telling him to install one). The car ran beautifully until he decided to install a twin entry setup that he had layin around from his st185. I dont think this would be the cause but it quite possibly could be.
Going from a stop on accel. it bogs, spits, sputters, pops, hesitates as soon as the boost comes on according to the gauge. It kinda feels like boost leak on MAF sensor car. His narrowband A/F guage reads lean while this is happening then goes rich and takes off like a rocket.
Compression is at around 180psi on all cylinders, ignition timing is at 5 deg., swapped map sensors with the one from my st165, changed spark plugs, tried running it n/a and it still acts the same.
There are no codes in the ECM.
Just curious if anybody has experienced this or something similar.
Any help is greatly appreciated. Thanks
88 Celica Alltrac
93 Lexus SC300( 1JZ swap)
post Aug 18, 2010 - 5:45 PM
Culpable04
Joined Apr 17, '06
From New Jersey
what are you guys using to tune the fuel ?
This post has been edited by Culpable04: Aug 18, 2010 - 5:45 PM
post Aug 18, 2010 - 6:38 PM
TurboToys
Joined Mar 9, '05
From Vandalia, Ohio
QUOTE (Culpable04 @ Aug 18, 2010 - 6:45 PM) *
Nothing, i know he needs an safc and i keep telling him that but he never got anything for it. His reasoning is because his narrowband A/F gauge would always stay rich when he was boosting and it ran so good. I'm amazed it hasn't blown up yet lol. The car has atleast 5k miles on this setup and around 86k on the original untouched engine.
It seems to happen more once the engine starts to warm up, he said it doesn't do it when the engine's cold. Possible ECT sensor maybe?
88 Celica Alltrac
post Aug 18, 2010 - 6:51 PM
Culpable04
Joined Apr 17, '06
From New Jersey
he needs something to tune the fuel with if he really wants to fix that, and even then depending on the capabilities of his option, he may still have little burps and what not, the better the tuning the better the engine will run.
I'm surprised he didn't have this same issues with the previous turbo, but a twin entry turbo is a lot more efficient than the single entry ct26, so maybe that's why the issue is pronounced enough for him to notice it.
post Aug 18, 2010 - 9:33 PM
TurboToys
Joined Mar 9, '05
From Vandalia, Ohio
Thats kinda what i was thinking, since i know that the twin entry spools a lot faster and is more efficient.
I just wish i had a wideband that i could put on it so i could accurately see what the afr's are doing.
88 Celica Alltrac
Lo-Fi Version Time is now: September 12th, 2026 - 8:02 PM
