> ST205 Boost Problem, Only hitting 3/4 boost on the stock guage
post Aug 18, 2010 - 11:30 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
I got my car about 2 weeks ago, and it does't hit full boost on the stock guage like those I see on youtube, There is no check engine light, I already reset the ecu, one day the boost went right up out of the blues and it pulled like crazy, but next day it stopped, any ideas anyone?? Any input is appreciated, I don't think its a boost leak because it doesn't fall back, it just stops around 3/4 up the boost guage and sometimes crawl up the rest of the way(sometimes).
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Aug 19, 2010 - 6:33 AM
Anabolik
Joined Feb 16, '08
From Russia, Kemerovo
QUOTE (cax_11 @ Aug 19, 2010 - 11:30 AM) *
I already gave a lot of advice. There is another idea, perhaps a catalyst, he just struggled or scattered. rolleyes.gif
I was such. The pressure did not rise above 0.5 bar.
sorry for my english)
Celica GT-Four'96
Corona Premio GT-Four
Curren Club-Russia
I on YouTube
post Aug 19, 2010 - 6:56 AM
cax_11
Joined Aug 15, '10
QUOTE (Anabolik @ Aug 19, 2010 - 7:33 AM) *
Was just seeking more advice, to see if anyone else had the same problem, and I don't have a boost guage other than stock as yet so I can't raise boost,
I am thinking about guttin the cat soon thought, I hope that helps my problem.
Nevis, West Indies
post Aug 19, 2010 - 12:39 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
sounds exactly like a boost leak. check the vacume lines on the wastegate or in your piping
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 19, 2010 - 12:42 PM
cax_11
Joined Aug 15, '10
QUOTE (Smaay @ Aug 19, 2010 - 1:39 PM) *
Will check for boost leaks later. But it puzzles me because for about a day it worked flawlessly, boost right up everything ok, then all of a sudden, began doing the same thing again. frown.gif
Nevis, West Indies
post Aug 20, 2010 - 2:20 PM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
Maybe your gauge is just messed up....buy an aftermarket gauge and check your boost level then. I've heard the stock gauge isn't that great anyway.
post Aug 20, 2010 - 2:21 PM
cax_11
Joined Aug 15, '10
QUOTE (CELL_PROTOTYPE_X @ Aug 20, 2010 - 3:20 PM) *
Thanks, already on my to buy list, ordering one soon
Nevis, West Indies
post Aug 20, 2010 - 2:42 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
my stock gauge doesn't go above 3/4 while the aftermarket one shows 12psi at full boost.
Can you feel a lack of boost or are you relying on your gauge to tell you?
ST205 Crew represent
Challenge Accepted
post Aug 21, 2010 - 12:29 PM
salv
Joined Feb 9, '10
From Kitchener, Ontario
Best way to find out is to get an aftermarket boost gauge.
Also, The ECU actually affects the amount of boost your turbo is going to give out depending on the conditions it detects (8-10psi in 1st and 2nd gear and anywhere from 10-14 psi on all other gears)
ST205 WRC
13.2 @103mph
post Aug 29, 2010 - 11:07 AM
cax_11
Joined Aug 15, '10
QUOTE (schmooot @ Aug 20, 2010 - 3:42 PM) *
The stock guage went all the way for a few hours one time, and I felt a huge difference. I am in the process of getting an
aftermarket boost guage to see exactly what it does. Cause I've heard that the stock guage isn't very accurate.
QUOTE (salv @ Aug 21, 2010 - 1:29 PM) *
But about what rpm should the turbo be a full boost?? Because with mine it only closes in on full boost at like 5-7k rpm.. (on the stock boost guage)
Nevis, West Indies
post Aug 29, 2010 - 11:20 PM
schmooot
Joined Sep 29, '09
QUOTE (cax_11 @ Aug 29, 2010 - 9:07 AM) *
its not that the stock gauge isn't accurate...it is just far too slow to get up to the boost level that the turbo is producing. The needle should rise at least as fast as your rpms...my aftermarket gauge is already showing my max boost before the stock gauge barely makes it past zero.
Challenge Accepted
post Aug 30, 2010 - 1:33 AM
Nial
Joined Aug 25, '08
From England
Have you done an error code check??
This post has been edited by Nial: Aug 30, 2010 - 1:35 AM
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Aug 30, 2010 - 2:54 AM
Driveby
Joined Sep 17, '05
From Newcastle / UK
Check the coolant level in your charge cooler.
1994 JDM GT4 WRC
post Aug 30, 2010 - 4:25 PM
cax_11
Joined Aug 15, '10
QUOTE (Driveby @ Aug 30, 2010 - 2:54 AM) *
Already did, when I open the cover, its running out, and thats when the engine is cool, and there is no check engine light.
Nevis, West Indies
post Aug 30, 2010 - 4:32 PM
cax_11
Joined Aug 15, '10
yep, has no codes store, lights flashes continuously.
QUOTE (schmooot @ Aug 29, 2010 - 11:20 PM) *
Ok then, guess I'll wait until my guage arrives to do more tests. My flex pipe in the exhaust is leaking, but am sure that would have nothing to do with it
Nevis, West Indies
Lo-Fi Version Time is now: September 13th, 2026 - 10:32 PM
