> ECU, Speedometer and Stock Wheel Size
post Aug 23, 2010 - 4:21 AM
fgvillegas
Joined Mar 22, '10
From Philippines
I'm just wondering if the ECU is programmed based on the stock wheel size to show a more accurate speed in the speedometer.
The reason why I'm asking has something to do with engine swaps. There are some who got a 3rd gen 3sge from a celica whose stock wheel size is 16s and install it in a corolla whose stock wheel size is 14s but uses 15s instead. In this case, there would be a slight (ignorable) difference in the speed reading so if 16s would be installed in the corolla, the speed reading would be the same as when it was installed in the celica.
Do I have the right analysis?
Thanks!
Lo-Fi Version Time is now: August 28th, 2026 - 4:08 AM
