> Door Dinger Removal?
post Sep 3, 2010 - 5:06 PM
RockyMountainCel...
Joined Aug 11, '10
From Alberta
I myself HATE listening to "DING DING DING DING DING" when my door is open, is there anyway to disconnect it? In my 2003 Hyundai Elantra it was very simple, just unplug it, there was a DIY posted on that forum with pics to help you find the unit.........anyone know where ours is?
2009 Chevy Cobalt SS Turbo "Torque Monkey" SOLD
1993 Honda Civic Si "Mean Green Cornering Machine" Track Whore
1995 Toyota Celica GT "Baby Supra" Daily Driver
Replies (1 - 7)
post Sep 3, 2010 - 9:06 PM
mgnt232
Joined Mar 16, '09
there was a thread on this a while back.... found it ►Click Here for Link◄ smile.gif
Its a little more complicated, depending on what you are looking/capable of doing, you can also just get a little clamp type thing to clamp the sensor down, so it seems like the door is closed, I know I have done that a few times smile.gif
Make sure you read through a bunch of the posts, i'm pretty sure there was some discrepancies on how to do it correctly, and may have been fixed down the posts, but im not 100% sure.
GL (I hate! that beep lol)
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Sep 7, 2010 - 4:26 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
on your ignition switch there is a 2pin connector. unplug it, put key in and open door.
dings - wrong connector (probably the key light if its a gt)
no ding - you did it (yay)
post Sep 8, 2010 - 10:10 AM
mkernz22
Joined May 10, '10
From MA
You have to take off the plastic panel off under the steering wheel, it's the one that has the precut holes to put switches in (It has 4 screws). Then remove the panel under that (4 - 10mm bolts hold it up). Also pull off the panel that goes around the ignition, gauge cluster, and steering wheel. It will help you see what you are unplugging. After that, you will have to reach up to the ignition column from underneath and look for a 2 wire plug, I believe the wire colors are green, but I will double check that for you later though. You can track the two wires from the front of the ignition column to the back of it (where the plug will be). The wires are located on the under side of the of the column. Hope that helps you!
post Sep 10, 2010 - 8:06 AM
babi_boi
Joined Feb 10, '09
From pa
ok, so I am not exaclty sure on what everybody is talking about with the stearing column. But there is a much much easier way to complete this, NO TOOLS REQUIRED. I will try to explain it, then i will show you a couple pictures.
First, pull up the plastic piece that runs along the bottom of the door, when you open your door.
Second, you simply peel back the plastic trim that covers the interior. (next to the back seat) (And by your dinger button)
Third, you unplug the dinger sensor plug thing.
And fourth, tuck wires back into plastic and put it all back together. Easy as 1234. biggrin.gif
Your dinger button
Plastic interior pulled back
Wire plug sensor thing that you unplug. Now just put it back together and wala no ding.
BABI BOI
post Sep 10, 2010 - 12:37 PM
demonofsteel
Joined Aug 18, '10
Unplugging the sensor button thing would work, but it's not the best way to do it. The car will believe your doors will always be closed and the light in the dash showing that doors are openned will never turn on.
Even worst would be for people who have alarm systems in their cars. Ususally, the alarm system is wired to detect if a door is openned. If you remove unplug the sensor button thing as mentionned, you will loose a very nice function of your alarm.
Maybe some people don't mind doing it this way, but it's not such a good idea.
The best way is to do it the harder way (but it's still very easy) by unplugging the connector next to the ignition switch that goes to the dinger.
post Sep 10, 2010 - 12:41 PM
babi_boi
Joined Feb 10, '09
From pa
QUOTE (demonofsteel @ Sep 10, 2010 - 12:37 PM) *
Your completely right. I didn't even think about the whole alarm thing. My bad. But it does stop the dinging. wink.gif
BABI BOI
post Sep 13, 2010 - 5:34 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
and also the auto headlight shutoff feature will cease to work, as it only shuts off when the driver door is opened, too
Lo-Fi Version Time is now: June 23rd, 2026 - 7:30 PM
