Sep 10, 2010 - 4:37 AM
Enthusiast ![]() Joined Mar 22, '10 From Philippines Currently Offline Reputation: 0 (0%) |
i upgraded my cams yesterday to 272 duration and 9.3 lift for both intake and exhaust. i noticed that my engine became so noisy. it's like someone's working on a typewriter.
my mechanic said that it's natural because i used stock valve springs. my tappets, according to him, is also within specs so i don't need to worry. after driving so long, i also noticed that my oil pressure is almost zero. my sensor connection is okay and when i rev the engine, the reading goes up also. again, according to my mechanic, it is natural for the oil pressure to go lower than usual when you upgrade cams and the reason why i am probably getting a very low reading is that my gauge may not be very accurate. btw, the brand of my gauge is autogage and my cams is Jun. please enlighten me on this. i plan to go to the dyno shop on monday and i'm not sure if this already okay. thanks guys. |
fgvillegas Noise After Cams Upgrade Sep 10, 2010 - 4:37 AM
Smaay your mechanic is dead WRONG! installing cams h... Sep 10, 2010 - 8:35 AM
fgvillegas that's what i'm thinking also cause i real... Sep 10, 2010 - 9:05 AM
Smaay DOHC = Dual over head cams. old school V8's h... Sep 10, 2010 - 1:26 PM
fgvillegas thanks for explaining it further.
my dilemna now ... Sep 10, 2010 - 6:04 PM
presure2 sounds like you need a valve shim adjustment, and ... Sep 11, 2010 - 6:08 AM
fgvillegas QUOTE (presure2 @ Sep 11, 2010 - 7:0... Sep 11, 2010 - 5:21 PM
Rusty I'd get it fixed asap
from the 3S-GE repair m... Sep 12, 2010 - 1:33 AM
fgvillegas QUOTE (Rusty @ Sep 12, 2010 - 2:33 A... Sep 12, 2010 - 5:20 AM
fgvillegas btw, in addition, what would happen if valve clear... Sep 12, 2010 - 5:46 AM
presure2 QUOTE (fgvillegas @ Sep 12, 2010 - 6... Sep 12, 2010 - 8:11 AM
fgvillegas what about the effect of not having the valve shim... Sep 12, 2010 - 4:44 PM
presure2 QUOTE (fgvillegas @ Sep 12, 2010 - 5... Sep 12, 2010 - 4:57 PM
Smaay if the valves are too loose, that would cause the ... Sep 12, 2010 - 6:08 PM
fgvillegas so putting your answers together, then valves that... Sep 13, 2010 - 1:11 AM
Smaay loose valves wont really demininsh closing, but it... Sep 13, 2010 - 9:48 AM
fgvillegas QUOTE (Smaay @ Sep 13, 2010 - 10:48 ... Sep 14, 2010 - 2:12 AM
fgvillegas btw, do i have to remove the cams and the camgears... Sep 15, 2010 - 12:25 AM
Rusty a whole lot of stuff, best to check the repair man... Sep 15, 2010 - 2:34 AM
fgvillegas QUOTE (Rusty @ Sep 15, 2010 - 3:34 A... Sep 15, 2010 - 8:45 AM
fgvillegas i went to my tuner today to have a second opinion.... Sep 16, 2010 - 5:50 AM![]() ![]() |
| Lo-Fi Version | Time is now: June 9th, 2026 - 7:36 PM |
