> help removing ignition lock cylinder?, re-keying my car.
post Sep 14, 2010 - 10:42 PM
Badkarma
Joined Apr 23, '06
From Rochester, NY
i need to remove the ignition lock cylinder. i dont want to just replace my door lock, and use two keys for locking and starting the car. i tried searching how to remove the lock cylinder. didnt find anything.
if someone could give me a pointer. id appreciate it.
Thanks
post Sep 15, 2010 - 6:15 PM
Demios
Joined Apr 16, '09
From Italy
Hmm i think you have to remove the whole block, with the lock steering...it's not easy...when i did it on mine i took one hour or more 'cause you the to break the screw that locks it, it has no head to be harder to steal...i think you can't remove only the cylinder...
post Sep 15, 2010 - 7:58 PM
mkernz22
Joined May 10, '10
From MA
No man, you don't have to remove everything.
Here's the process:
You have to pull off the plastic piece that is on top of the steering wheel and in front of the ignition column.
Then, you have to put the key in the ignition and turn it to the On position, NOT start.
Get a small screw driver and find the hole on the top part of the ignition column near the front.
Put the screw driver in there, press down, and put the key toward you and the inner part of the column should just slide right out.
Hope this helps!
The new one should just slide right in there as well, make sure you have the key on the On position before putting it in!
This post has been edited by mkernz22: Sep 15, 2010 - 7:59 PM
post Sep 15, 2010 - 9:13 PM
QUOTE (mkernz22 @ Sep 15, 2010 - 8:58 PM) *
Here's the process:
Hope this helps!
nice. Where'd you learn that Mike ? haha
post Sep 15, 2010 - 9:20 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Batman722 @ Sep 15, 2010 - 10:13 PM) *
Here's the process:
Hope this helps!
heard it from the grapevine haha
post Oct 7, 2010 - 6:34 PM
Badkarma
Joined Apr 23, '06
From Rochester, NY
thanks for the help. this went quick and easy! everything is all back together and one key to all locks now.
post Oct 7, 2010 - 8:44 PM
mkernz22
Joined May 10, '10
From MA
post Oct 8, 2010 - 10:58 PM
Araykhel
Joined Sep 21, '10
From Woodstock, MD
Holy hell man, you just made my evening telling me that.
post Oct 8, 2010 - 11:07 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (Araykhel @ Oct 8, 2010 - 11:58 PM) *
I'm glad that it helped you out as well!
post Oct 10, 2010 - 12:47 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
vote for sticky
2001 Solar yellow Lexus IS300
post Oct 11, 2010 - 2:27 PM
mkernz22
Joined May 10, '10
From MA
if this get stickied, all credit goes to dustin (batman722) lol
post Nov 13, 2010 - 12:28 PM
jacksonvilleFl94...
Joined Nov 13, '10
From jacksonville,fl
Sorry i'm new here mattere of fact I joined just now to ask if Anyone can help me uninstall the lock cylinder housing that i need to pull at the junk yard in order to install onmy now push button start? If anyone could help me or direct me to helpful instructions I would greatly appreciate the help, Thanks! in advance
Lo-Fi Version Time is now: July 29th, 2026 - 8:40 PM
