> removing rear quarter window?
post Sep 17, 2010 - 6:23 PM
georgie
Joined Jul 5, '09
From Toronto
Hey, so my window trim is cracked and missing pieces on the rear quarter window. How would i remove the window and install a new one?
post Sep 19, 2010 - 6:03 PM
georgie
Joined Jul 5, '09
From Toronto
no one? =(
post Sep 19, 2010 - 6:08 PM
mkernz22
Joined May 10, '10
From MA
You would need to get a steak knife to cut the rubber on the side closest to the pass and driver doors. (Just a little break through slice)
Then get a thin cutting wire from home depot, put it through that hole you made and make your way around the whole window.
It would be easier to explain with pictures, but I hope that helps and you get the concept of what I'm talking about.
post Sep 19, 2010 - 6:09 PM
this is probably something best left to a window professional
post Sep 19, 2010 - 7:59 PM
Projek_01
Joined Feb 18, '07
From Calgary, Alberta
that is what you need + a long knife. Cut from the interior
post Sep 19, 2010 - 10:08 PM
JasonTX
Joined Mar 1, '10
From TX
from what i've read the rear windows are bonded to the car w/ a sort of glue. once your remove the plastic body trim from the inside you can see it. you'll have to cut it out either with a tool like posted above or you might just try asking an autoglass place, one by me said thy would do it for 25 bucks if i take out the interior plastic, you can prolly find some shop close to give a simlar or better deal.
hope that helps i'm looking to do this soon too
jec
JN 3:16
post Sep 21, 2010 - 12:34 PM
georgie
Joined Jul 5, '09
From Toronto
thanks guys, i'll find a shop that'll do it for me. Didn't realise it was that much work
post Sep 21, 2010 - 4:58 PM
QUOTE (JasonTX @ Sep 19, 2010 - 11:08 PM) *
jec
All automotive FIXED windows (front, rear, quarter) are adhered with "glue"
you'll have to get window sealant adhesive to re-adhere the replacement back to the car + the required trim pieces
post Oct 12, 2010 - 11:37 AM
CelicaHD2
Joined Aug 15, '10
From UK
Hi guys...jusy to say I will put together a DIY on how to do this asap.
I am in the middle of customising/restoring my celica and giving it a fresh paint job so have removed the quarter windows, drip rail and window trims.
I shall get my pics up on a new thread asap.
Cheers.
Lo-Fi Version Time is now: September 14th, 2026 - 10:25 PM
