Sep 18, 2010 - 6:36 PM
Enthusiast ![]() ![]() Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
Hey Guys! Here is a list of all important fluids for our Celica. This data chart is currently for the 5sfe engine. I'll will be working on the 7afe soon. Thanks!
5SFE Fluid Data Specs. Application - Fluid Type : Capacity = Litres (U.S. quart , imperial quart) A/C Refrigerant. - R134a : 650 +/- 50g (22.93 +/- 1.74oz) Air Condition Oil - ND-Oil 8 or equivalent Brakes - SAE J1703 DOT 3 Clutch. - SAE J1703 DOT 3 Differential Oil (manual Transmission) - ATF Dexron II or III : 1.6L (1.7, 1.4) Engine Oil (Dry Fill)........................................ - SH "E-C II" : 4.3L (4.5, 3.8) Engine Oil w/filter change (Drain & Refill) .. - SH "E-C II" : 3.9L (4.1, 3.4) Engine Oil w/o filter change (Drain & Refill) - SH "E-C II" : 3.7L (3.9, 3.3) Engine Cooling System (Manual).... - Ethylene glycol base (no alcohol) : 6.7L (7.1, 5.9) Engine Cooling System (automatic) - Ethylene glycol base (no alcohol) : 7.1L (7.5, 6.2) Fuel Tank - Unleaded OR87 (RON91) or Higher : 60L (15.9 gallons, 13.2 imperial gallons) Power Steering - ATF Dextron II or III : 0.8L (0.85, 0.70) Automatic Transmission A140E (w/o differential oil) Dry................ - ATF Dextron II or III : 5.6L (5.9, 4.9) Drain & Refill - ATF Dextron II or III : 2.5L (2.6, 2.2) Manual Transmission S54 - API GL-3, GL-4 or GL-5 SAE 75W-90 : 2.6L (2.7, 2.3) This post has been edited by vile_v: Sep 18, 2010 - 6:45 PM -------------------- ![]() |
Sep 18, 2010 - 6:40 PM
Enthusiast ![]() ![]() Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
sweet! Thins needs to be a sticky
-------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
| Lo-Fi Version | Time is now: September 1st, 2026 - 12:39 AM |
