Sep 22, 2010 - 1:03 AM
Enthusiast ![]() Joined Sep 21, '10 From Woodstock, MD Currently Offline Reputation: 1 (100%) |
I've got a 95 Celica GT Convertible that has become my daily driver this late summer. I am in the process of replacing bits and pieces of the car but I have no experience with door-less windows such as the ones in the rear. What happens is on any given day whenever I lower the window it works perfectly fine, no strange noises or squeaks, however once my ride is over and I need to raise the rear windows up my right side won't come up. A better explanation would be that it doesn't budge, I hear no tell tale humming from the motor when the switch is hit, and when I try to take the weight off the glass of the assembly to aid the motor still no result. I have checked the wiring and voltage and can swear soundly that that is not the source of my problem. On some rare days the window will work just fine but out of fear I leave it up 24/7.
I would love to know if any others have experienced similar problems and whether or not my best plan of action would be to buy a new motor. I have done some research on replacing the window motor and I know it is going to be a pain if I have to do it myself, but I would much rather save on the expenses at a garage. P.s: The opposite side window has no such problems. This post has been edited by Araykhel: Sep 22, 2010 - 1:05 AM |
Sep 22, 2010 - 10:54 AM
Enthusiast Joined Aug 29, '09 From Ohio Currently Offline Reputation: 7 (100%) |
This has been discussed many times in this fourm. It is usually the switch contacts in the console. You have to take the switch out. Disassemble it. Clean the contacts off (they usually have carbon). People have used cleaner and wire brushes and everything. I put some dielectric grease on the contacts. then reassemble the whole thing. Plug it back in. Test the switch, reassemble the console. It usually works really well.
Sep 22, 2010 - 1:51 PM
Enthusiast ![]() Joined Apr 20, '10 From Virginia Currently Offline Reputation: 0 (0%) |
Yeah it's your switch I had the same issue. Like ajlee said take apart the switch clean it and put it back together. Works like new then
Sep 23, 2010 - 7:15 PM
I've suspected over the past few days that that might be the case but if it were then did the wiring check okay when I ran a voltmeter through? I will try to clean it up tomorrow after work, thanks for the responses.
Sep 24, 2010 - 11:58 PM
Just an update, I've sanded them down and applied a bit of dilectric grease with no luck.
| Lo-Fi Version | Time is now: August 9th, 2026 - 1:03 PM |
