Sep 25, 2010 - 6:47 AM
Enthusiast ![]() ![]() ![]() Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
One of my light bulbs bit dust and I need to replace it.
Further down the road I intend to replace both of them with Sylvania Silverstar Ultra 9006 SU/2 bulbs but right now I'm broke. I know that stock replacement for low beams is 9006/65W but can I use 9006/100W instead without risking blowing fuses or melting harness? -------------------- '94 ST |
Sep 25, 2010 - 12:33 PM
I've been running 9005 65w bulbs in my 9006 55w low beams for quite some time without issue, but I've never seen the 100w bulbs.
Sep 25, 2010 - 12:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
I rekon you will be riskying melting the harness, and ive never seen 100w bulbs. At least in australia, have you even thought about hids?
Sep 25, 2010 - 8:43 PM
Here is what I'm considering. I've been running similar (but 65W) for over a year now.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...e=STRK:MEWAX:IT How serious is the threat of actually melting the harness? -------------------- '94 ST |
Sep 26, 2010 - 10:33 AM
Nobody knows?
Sep 26, 2010 - 4:47 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
Straight from it's ad on ebay:
This Item is 100W Bulbs, Buyer Need To Check Wiring Or Fuse Before Installing Just get an HID Kit for you car, don't risk messing something up with these poser HID bulbs. |
Sep 27, 2010 - 5:26 PM
Can't afford HID conversion kit, right now...
Can't afford ticket for non-moving violation (i.e. busted headlamp) either. -------------------- '94 ST |
Sep 27, 2010 - 5:47 PM
you got a ticket for having a broken headlight?...
Sep 28, 2010 - 1:19 PM
you got a ticket for having a broken headlight?... Not now for this one, but I got one couple years ago... They call it "fix-it-ticket", as soon as you can prove it that it's fixed then you get the ticket wiped out clean, but you have to go to court and loose a day at work. Either way it's too much hassle. Trying to avoid it. -------------------- '94 ST |
| Lo-Fi Version | Time is now: August 1st, 2026 - 11:02 AM |
