> hks s40i spark plug
post Sep 25, 2010 - 6:19 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
I remove spark plug in my jdm st205 engine recently import
it is hks s40i ... at heat range 8 ?
before I remove hks plug I buy BKR6EP-8 at heat range of 6
why is best of use s40i?
thanks
Celica GTS turbo 1994
3sgte genIII Ct20b
Replies (1 - 3)
post Sep 26, 2010 - 8:42 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (3rdgen3SGTE @ Sep 25, 2010 - 7:19 PM) *
thanks
not sure if i quite understand, but if youre wondering if its ok to use he replacement plug you got the answer is yes. stock 3sgte motors run a heat range 6 plug. HOWEVER you can go colder depending on your performance desires (to reduce the chance of detonation) imho a range 8 plug is a bit overkill unless there were some heavy mods done to the motor or the previous owner was running a lot of boost on it.
im thinking if the previous owner was putting a cold plug like that in it, he was running the hell out of that motor or did some mods to it. if i were you i'd inspect the motor more.
most of us use 7 range on here BKR7e Ngk but they changed the part number kindasad.gif wished knew the new part number for ya!
post Sep 27, 2010 - 9:47 PM
3rdgen3SGTE
Joined Nov 21, '05
From Quebec
thank you
3sgte genIII Ct20b
post Sep 28, 2010 - 12:16 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
Lo-Fi Version Time is now: August 21st, 2026 - 11:49 PM
