> WTB Drivers side front seat Hinges/splash guards/ Hood Insulation
post Sep 27, 2010 - 11:07 AM
Originalfuture
Joined Jan 24, '06
From USVI
94-98 GT hatchback ------I am looking for just the driver side metal hinges and rails that are on the bottom of the seat and attaches the the back part to the seat.(Metal and plastic mechanism only) ***(I don't need the cushions.)****
Also anyone has the engine and transmission splash guards in good condition please give me a price.
Also looking for the Heat insulated hood liner and clips.
This post has been edited by Originalfuture: Sep 27, 2010 - 11:11 AM
Replies (1 - 4)
post Sep 27, 2010 - 2:59 PM
mkernz22
Joined May 10, '10
From MA
you honestly don't need the liner under your hood, it actually keeps the heat in. I took mine off and noticed a slight drop in the running temperature. The main reason for it was if your engine caught fire for whatever reason, the clips would melt and then the insulation would cover the fire thus putting it out.
post Sep 29, 2010 - 12:54 PM
Originalfuture
Joined Jan 24, '06
From USVI
QUOTE (mkernz22 @ Sep 27, 2010 - 3:59 PM) *
I was worried cause my engine runs extremely hot. Is that something common.
post Sep 29, 2010 - 2:25 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (mkernz22 @ Sep 27, 2010 - 2:59 PM) *
Woah, never thought of that haha. I new it was to keep the heat in but never thought it could make a fire go out.
I keep mine uder the hood as the cold weather is comming, but I probably will take it out when summer will be back.
You don't need it, but it helps when it's cold.
You say your engine runs very hot.. How hot? Where is your indicator at? Mine is at about 170 degrees (its angle, not the temperature), close to the heat thingy drawing in the cluster. If it's way over that, around 150 degrees or less, you might wanna change your prestone 1st and check if your radior is still good. If it's not much hotter, then it's nothing to worry about.
post Sep 29, 2010 - 8:21 PM
mkernz22
Joined May 10, '10
From MA
since I've gotten an aftermarket intake, mine has been running a lot cooler now, even at high speeds. When driving on side roads its just over a quarter of the way up and when im on the highway, it only gets to just under half.
Where is your needle at under normal driving conditions?
Lo-Fi Version Time is now: August 26th, 2026 - 7:06 PM
