> Caliper Locking up
post Sep 28, 2010 - 8:38 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Hey, For a while now my passenger side rear caliper has been locking up under hard braking, no leaks anywhere and it bled fluid out both sides fine. I rang up for rebuild kits and they were all $120-95 a side! so last time I was in the wreckers I got a caliper for the side that wasn't locking, still the same problem! today I re-greased the 2 outer caliper bolts but its still doing it, any ideas?
Anyway the passenger side rear caliper is working TOO well?
thanks.
- Euphoria   Caliper Locking up   Sep 28, 2010 - 8:38 AM
- - barterj   Is the other rear caliper working? Is the piston s...   Oct 5, 2010 - 10:43 AM
- - Euphoria   How do I tell if its stuck?   Oct 7, 2010 - 8:39 PM
- - bccentaur3   Are you lhd or rhd? depending on where the master ...   Oct 7, 2010 - 9:16 PM
- - azian_advanced   Use a big C-clamp and push it back in. Be sure to ...   Oct 7, 2010 - 9:31 PM
- - Euphoria   It only locks on hard braking, slow braking is fin...   Oct 7, 2010 - 9:39 PM
- - bccentaur3   well try adjusting the brake pedal. If you look at...   Oct 7, 2010 - 9:42 PM
- - Euphoria   Also It only does it when it gets hot, another rea...   Oct 7, 2010 - 10:14 PM
- - bccentaur3   Because its happened to me before.   Oct 7, 2010 - 10:16 PM
- - Euphoria   and you had one side only locking? because I thoug...   Oct 7, 2010 - 11:25 PM
- - bccentaur3   yes. Well one line goes to the MC but then it bran...   Oct 8, 2010 - 10:19 AM
- - Euphoria   well the car is a right hand drive and its the pas...   Oct 8, 2010 - 10:30 AM
- - bccentaur3   NOOOOOOOO!!!! not loosen the line ...   Oct 8, 2010 - 7:45 PM
- - Concept69   Check for restrictions in the brake lines like pin...   Oct 11, 2010 - 3:03 AM
- - Euphoria   Yeah there is no way its the brake pedal adjustmen...   Dec 14, 2010 - 11:13 PM
- - blackthunder   hrmm, I seem to be having a similar problem. I ha...   Dec 27, 2010 - 9:20 AM
- - Euphoria   Yeah I'm in a similar situation, I don't h...   Dec 29, 2010 - 9:53 PM
- - mkernz22   Maybe your system just applies too much pressure o...   Dec 29, 2010 - 11:20 PM
- - blackthunder   Well I made an appt. for the shop next week. I wi...   Dec 30, 2010 - 6:51 PM
- - nsxtypeR   Maybe the proportioning valve is at his end. It...   Dec 31, 2010 - 4:04 AM
- - Spider77   That sounds reasonable, since there are two separa...   Dec 31, 2010 - 6:08 PM
- - Euphoria   Thats probably what it is, how do you tell if you ...   Dec 31, 2010 - 10:46 PM
- - Spider77   RE: Caliper Locking up   Dec 31, 2010 - 11:18 PM
- - Spider77   I think there is a different way to check the valv...   Dec 31, 2010 - 11:25 PM
- - Euphoria   thanks! might be worth trying if they are not ...   Jan 1, 2011 - 12:18 AM
- - nsxtypeR   QUOTE (toyodiy)47150 VALVE ASSY, PROPORTIONING 471...   Jan 1, 2011 - 4:47 AM
- - Euphoria   Holy **** lol, think they sell them after market?   Jan 1, 2011 - 6:39 AM
- - Bitter   Have you replaced the rubber brake hose yet?   Jan 1, 2011 - 9:32 PM
- - Euphoria   I haven't but it bleeds fine so I don't se...   Jan 2, 2011 - 10:59 PM
- - blackthunder   well took her to the shop and they found that it j...   Jan 6, 2011 - 7:58 AM
- - Euphoria   Ah dam, looks like you got out the easy way, im 99...   Jan 6, 2011 - 8:01 AM
- - Euphoria   Well I've rebuilt both pistons at the back, st...   May 5, 2011 - 3:38 AM
- - Euphoria   Well I put on a used disc I had there and the prob...   May 10, 2011 - 5:41 AM
|- - brenton1919   u might have air in the line.... are u sure its no...   May 10, 2011 - 5:45 AM
- - Euphoria   It was only under braking, wheel bearing would be ...   May 10, 2011 - 5:49 AM
- - brenton1919   QUOTE (Euphoria @ May 10, 2011 - 6:4...   May 10, 2011 - 7:15 AM
Lo-Fi Version Time is now: September 18th, 2026 - 4:57 AM
