> Tweeters?
post Sep 30, 2010 - 3:54 PM
justin3
Joined Sep 27, '10
From Laredo
I want to install some tweeters in my 96 celica, i was wondering how was the best way of doing it? I was going to wire them staight to the front speakers from the radio and them mount them on the sides of where the radio is located, is there any trick to install them or can i just wire them together with the front speakers?
Replies (1 - 7)
post Sep 30, 2010 - 4:21 PM
mgnt232
Joined Mar 16, '09
I thought GT's had tweeters? I guess I was wrong.
Anyhow if they are not there, the best thing to do would be get a "crossover". Which (everyone is different) will allow you to have the front speakers and the tweeters working together. And getting the right frequency for tweeters mainly. If you just wire them together it will work, just wont sound the best, and im sure it messes with the ohms of it and all (not real important with low power like front speakers)
But anyhow the interior mirror covers are the best spot for the tweeters. Just look, there is a triangle piece that pops right off, and you can drill out a whole for the tweeter and it will look great (make sure the whole if the right size).
Also with doing it on the sides, if you dont like it or whatever its going to be more expensive to replace those pieces than the small triangles.
I have a crossover with my rear speakers, and tweeters and it sounds really good. I had it just wired up before with no crossover, and every "low bass" note the tweetes just didnt know what to do lol. Sounded really bad, but the crossover fixed it and they are quite cheap
GL smile.gif and hope that helps
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Sep 30, 2010 - 4:51 PM
richee3
Joined Jun 29, '08
From Denver
I know you want OEM-esque tweeters, but why not just get two way speakers? Get some good speakers in your doors, and have tweeters already in there.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 30, 2010 - 4:58 PM
justin3
Joined Sep 27, '10
From Laredo
that sounds good i might just do that instead!
post Sep 30, 2010 - 5:05 PM
richee3
Joined Jun 29, '08
From Denver
No problem. I was just trying to figure out why you were going for OEM-style tweeters rather than going with 2 way speakers.
1998 Celica GT-
BEAMS Swapped.
post Sep 30, 2010 - 5:57 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
OEM style has much better positioning. i had the 2ways, then upgraded to a component infinity reference and put the tweeters in the stock location. sounds perfectly clear and crisp, while the 2ways were a little washed out or muffled sounding. the OEM tweeter covers are ~$50 from Toyota.
post Oct 2, 2010 - 5:17 PM
diegohiga
Joined May 4, '09
From coral springs florida US
this is my tweeter 4 inches. sounds really nice and is hooked up to my amp
post Oct 2, 2010 - 6:09 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
Just by a 2 way component system. You'll have the tweeter, mid and crossover. Components sound much better than 2 way loudspeakers.
1999 Celica GT Hatchback
Lo-Fi Version Time is now: September 13th, 2026 - 9:08 AM
