> smoke on startup, engine **** that bugs you
post Sep 30, 2010 - 7:38 PM
Agent99
Joined Aug 31, '09
From Stumptown! (PDX Oregon)
Hey gearheads (!holla)
Normally I'm in my own little world during startup in the morning.
Finish drinking coffee, thinking bout school/work/randoms.
Then I see fog in my rearview on a clear day... hunh?
I start watching every time, and on cold cold days, it smokes on startup.
About a car sized fogbank for the first 5 seconds, then it runs clear.
It's only 135 on the clock. What am I in for? Valve stems worn and leaking oil
into the cyls when shutdown? Can't be rings already? Gaskets?
So actions? Ignore? Compression test? Screw it and race til dead?
Its the 2.2 fwiw.
Agent 99
Replies (1 - 10)
post Sep 30, 2010 - 7:49 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
valve stem seals. nothing to worry about. just stay on top of your oil. my ST does it to a much lesser extent at over 200k mi.
compression test will check the rings if ur worried
post Sep 30, 2010 - 7:53 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Exactly^^ mine does the same...and leaks...its an oil whore lol.
Its a 10+ year old engine,its not gonna be perfect haha.
This post has been edited by SupraKid: Sep 30, 2010 - 8:04 PM
post Sep 30, 2010 - 7:57 PM
richee3
Joined Jun 29, '08
From Denver
The 5S-FE does that. Nothing to worry about. Just check your oil every so often.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 30, 2010 - 8:08 PM
Agent99
Joined Aug 31, '09
Yeh, I pour a bunch of expensive Redline Oil into it...
some days it seems to take as much as my 2 stroke bike!
So, !thanks guys, just going to run it and not sweat it.
I love this little car, it's a keeper.
post Sep 30, 2010 - 8:11 PM
Remy
Joined Jan 25, '06
From MN
Just replace the valve seals and get a valve adjustment while your at it, its normal on high mileage engines but not something you should ignore.
"To Protect And To Serve The Wealthy" -POLICE
post Sep 30, 2010 - 11:47 PM
conus00
Joined Jul 10, '08
From Tampa, FL
Mine smokes on start, too. Not as much as yours, though.
Like everybody says: stay on top of your oil and you should be fine.
Also, you can get bottle of Slick50. I was very skeptical about it but it works.
'94 ST
post Oct 1, 2010 - 12:07 AM
Spectorious
Joined Feb 24, '09
From Scranton, PA
i dump a quart of lucas oil treatment in evry time i change my oil and it helps with the smoke problem ALOT
post Oct 1, 2010 - 5:04 AM
smirnoff
Joined Dec 12, '09
From N.Ireland
What colour is the smoke?
post Oct 6, 2010 - 10:20 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
I have the EXACT same problem. You guys says it's the valves' seal? Mine has 140 kms on it.
This post has been edited by dudeofchaos: Oct 6, 2010 - 10:20 AM
post Oct 6, 2010 - 10:24 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Leaky valve stem seals are VERY common in 5S Toyotas. My MR2 does it as well.
**** Photobucket
Lo-Fi Version Time is now: August 31st, 2026 - 11:04 AM
