Oct 9, 2010 - 10:37 PM
Enthusiast Joined Jul 29, '10 From norwoord, MA Currently Offline Reputation: 0 (0%) |
So I was driving the car for the first time in a week or 2, and the brakes felt a little funny. Also smell something like an "electrical fire". But no smoke or anything. All other fluids seem to be fine.
The very top right container next to the diagnostics box is low (is this brake fluid?) and My master cylinder next to that is low. My car is garage kept, so I would see obvious drips, and none are there thanks This post has been edited by slickr: Oct 14, 2010 - 1:29 PM |
slickr Low brake fluid - No obvious leaks Oct 9, 2010 - 10:37 PM
Bitter check your brakes, they can be low which lowers th... Oct 9, 2010 - 10:52 PM
zoik check the wear of your brake pads. when used, the ... Oct 10, 2010 - 5:05 AM
slickr I am thinking you guys are right .
The brakes just... Oct 10, 2010 - 5:54 PM
solidxsnake Sounds like you have a stuck piston. Try jacking t... Oct 10, 2010 - 9:21 PM
zoik QUOTE (solidxsnake @ Oct 10, 2010 - 10... Oct 10, 2010 - 9:59 PM
slickr That makes sense, dont know why i didnt think of n... Oct 10, 2010 - 11:23 PM
Concept69 Just monitor the brake fluid. If you see it gettin... Oct 11, 2010 - 3:30 AM
slickr jacked up each tire individually, to find that the... Oct 11, 2010 - 8:04 AM
zoik QUOTE (slickr @ Oct 11, 2010 - 9:04 ... Oct 11, 2010 - 9:57 AM
slickr But do you think I need a new one, if after I push... Oct 11, 2010 - 6:34 PM
stephen_lee ok guy reservoir next to the diag box is your clut... Oct 11, 2010 - 7:40 PM
solidxsnake Yeah, the picture you took is of the clutch master... Oct 11, 2010 - 8:55 PM
slickr Ok, thanks for actually answering me lol What cou... Oct 11, 2010 - 10:07 PM
solidxsnake If the clutch is fine, you're probably fine. C... Oct 12, 2010 - 8:24 AM
slickr Filled the reservoir, going to get the caliper now... Oct 12, 2010 - 11:07 AM
stephen_lee bleed all the brakes, starting at the passenger re... Oct 12, 2010 - 6:28 PM
slickr I think I need new rotors and pads...
I bled the ... Oct 14, 2010 - 1:28 PM
stephen_lee no. if theres no obvious damage to your rotors you... Oct 14, 2010 - 3:33 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 25th, 2026 - 10:10 AM |
