Oct 12, 2010 - 5:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I just replaced my clutch and rear tranny mount and flushed the old fluid, and now it seems the car is having trouble shifting into third gear. All other gears seem fine, and this wasn't an issue prior to having the transmission out. I know the fluid is at the correct level, and everything is bolted on properly so i'm not quite sure what to think. How could a synchro go bad from literally doing nothing? Any thoughts or suggestions?
I forgot to add....I also have trouble shifting into first gear when the car is stopped. It seems like all of the gears are locked up, I have to let off the brake and let the car roll a little bit. Then it pops in no problem. -------------------- ![]() |
Oct 12, 2010 - 5:15 PM
bleed it again.
| Lo-Fi Version | Time is now: August 23rd, 2026 - 2:26 PM |
