> can someone email me a picture of the celica 5sfe manifold?, 95 - 99 celica
post Oct 12, 2010 - 9:58 PM
match220
Joined May 13, '06
From Kaimuki, HI
my email is theshipp@gmail.com, I would explain why I need this picture, but it's a little complicated, i'll explain later. I just need a picture of the area around the injectors. Clear pic, preferably with the manifold off of the engine and nothing bolted into it, but one will do if it is on the car, as long as I can see around the injectors clearly. Thanks!
This post has been edited by match220: Oct 12, 2010 - 10:01 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
Replies (1 - 3)
post Oct 12, 2010 - 10:25 PM
fgvillegas
Joined Mar 22, '10
From Philippines
if you are referring to the intake manifold, check this link -> http://picasaweb.google.com/lh/photo/rPrNZA5_s3-ewe7y4rbRLQ
it's the one at the left. the one at the right is for 3sgte
hth
post Oct 12, 2010 - 11:35 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (fgvillegas @ Oct 12, 2010 - 5:25 PM) *
hth
hmm..well, here goes my question. I don't have a 5sfe in my celica anymore, I have a gen III 3s in it right now, but for financial reasons I'm trying to sell the engine and get a stock 5sfe from the auto salvage yard here. As a mechanic though, I've worked on a lot of 5sfe engines from camry's and some celicas, and on some of them I saw injectors on the manifold, and some have injectors on the head (unless I'm getting confused from working on my 3s too). So I'm going to try to run two injectors per cylinder and see if I can configure my Autronic SM4 EMS for running both of them. And if I can get a spare intake manifold I'm going to try to cut a hole in the other side and mount another TPS and throttle body for a dual air inlet. BUT I don't remember which manifolds had the injectors on the head and which had them on the manifold. If the manifolds are all bolt on/interchangeable then this will be a lot easier. And I'll be running coil over plugs (if my R6 cop's fit in the head).
So if everything goes according to plan, I'll have a dual injection, digital ignition, twin intake, high rpm N/A celica! hopefully
-Jay
post Oct 12, 2010 - 11:57 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
they both are in the head
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: August 23rd, 2026 - 7:47 PM
