Oct 15, 2010 - 7:20 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
don't mean to steal your thread...but i have a noise in the front of my car too....it rattles more than clunk noise....only when i accelerate and when car is warm up while accelerating...up past to higher speed.... it disappears. what could this mean? A loose object. Really you need to be more specific because it could be your wheel, strut, bearing, axle, tie rod, exhaust, heat shield, battery, exe. pretty much anything and everything can rattle under the hood. i have a e153 tranny and the mr2 inners and alltrac outter axles all hooked up. been running it for a years now without a problem..just recently i started to notice a clunking noise coming from the front left(when inside of the car) axle. i can feel movement/something happening from the inside of the car a clunking/thumping noise. at first i thought i had something loose. i lifted the car up and checked and double checked everything...everything is down to torque. dropped the car back down and the noise went away for a few days...i took like 2 or 3 hard turns and the noise came back! decided this time to lift the car up and throw her in gear. some crazy clicking noise came was happening from the axle/tranny. only happens in gear or while the axle is moving. so i decided to single the noises out. at first it sounded like the tranny..so i scope the tranny and it was good, even did a tranny flush and refill. noise was still there...so i decided to scope the axle, the cluncking or clicking noise seems to be coming from the inner bearing of the axle (where the mr2 inner goes into the tranny and the alltrac axles breeeds into the inner mr2 part? has anyone ever heard or had a similar problem? do you guys think its a axles bearing problem or do you guys think its from the tranny.. i can feel a thumping noise under my feet as i drive..it feels like for example if something was loose and it just falling/hitting the axle while it was spinning. any help would be great... -------------------- ![]() |
RUNNIN-LOW cluncky/clicky + thumping noise? = tranny or axle Oct 15, 2010 - 7:20 AM
presure2 its alot more likely a axle issue. sounds like the... Oct 15, 2010 - 8:19 AM
stephen_lee BTW 91 v6 camry axles should work.. you can hop in... Oct 15, 2010 - 9:15 AM
RUNNIN-LOW yeah im going to try and pull the axle this weeken... Oct 15, 2010 - 10:32 AM
stephen_lee um. the whole assy will unbolt from the inner stub... Oct 15, 2010 - 12:07 PM
RUNNIN-LOW yeah i know...just sayin i might take the inner pa... Oct 15, 2010 - 12:39 PM
stephen_lee Howd it go? Oct 20, 2010 - 5:36 PM
presure2 he told me yesterday in the chat that the cage was... Oct 21, 2010 - 7:36 AM
RUNNIN-LOW yes it worked untill this morning! no clue wha... Oct 21, 2010 - 9:20 AM
KAOS Ugh - brutal. So you're saying that you fixed ... Oct 21, 2010 - 9:35 AM
RUNNIN-LOW yeah i replaced the whole axle. since the other on... Oct 21, 2010 - 10:59 AM
stephen_lee So did you use 185 axles or camry V6?
are you usin... Oct 21, 2010 - 5:41 PM
RUNNIN-LOW did some research and lifted the car up last night... Oct 22, 2010 - 6:49 AM
RUNNIN-LOW alright first off THANKS TO ALL THE PEOPLE THAT HE... Oct 29, 2010 - 9:55 AM
bccentaur3 Congrats Johnny boy. Where did you get the spacer? Oct 29, 2010 - 2:08 PM
RUNNIN-LOW celi_6
hey i couldnt send you the pm...
i actual... Nov 15, 2010 - 8:44 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:14 AM |
