> coolant bypass pic.
post Oct 22, 2010 - 11:47 AM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
i found this pic that gives you an idea if anyone is looking to do a throttle body coolant bypass. i found it helpful so i hope it helps you guys.
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
- 4-eyed-freek   coolant bypass pic.   Oct 22, 2010 - 11:47 AM
- - Robbie1902   How do you go about doing this and what are the be...   Oct 24, 2010 - 12:28 PM
|- - Johnnyny   QUOTE (Robbie1902 @ Oct 24, 2010 - 1...   Oct 24, 2010 - 1:21 PM
- - Robbie1902   No i know that im just asking how to do it and whe...   Oct 24, 2010 - 1:39 PM
- - 4-eyed-freek   where it says iac in the pic. take the two lines t...   Oct 24, 2010 - 3:42 PM
- - Robbie1902   Haha thanks i looked at the pic again and was like...   Oct 24, 2010 - 4:02 PM
- - 4-eyed-freek   yup no problemo.   Oct 24, 2010 - 4:42 PM
- - luka   know what size fitting that is?   Oct 24, 2010 - 7:09 PM
- - 4-eyed-freek   i used a 3/8. its was a really good fit. make sure...   Oct 24, 2010 - 7:17 PM
- - 4-eyed-freek   this is why i say do this when the engine is cool....   Oct 24, 2010 - 7:25 PM
- - Remy   The only REAL benefit you gain from capping off th...   Oct 24, 2010 - 7:43 PM
- - azian_advanced   there is no gain in power by removing the throttle...   Oct 24, 2010 - 8:03 PM
- - Robbie1902   It will help with heat tho, the less heat in the t...   Oct 24, 2010 - 8:59 PM
|- - Bitter   QUOTE (azian_advanced @ Oct 24, 2010 - 9...   Oct 24, 2010 - 9:41 PM
- - hatchy_gt-s   YAY!!! Someone actually knows common s...   Oct 24, 2010 - 10:16 PM
- - Spider77   Since we've gotten into this, I really want to...   Oct 25, 2010 - 6:33 PM
- - Hanyo   Just a warning to those who live where it snows. D...   Oct 26, 2010 - 1:28 AM
- - 4-eyed-freek   how would it get frozen if there is not liquid in ...   Oct 26, 2010 - 10:05 AM
- - Spider77   Ok, so today at lunch, I took some temp readings (...   Oct 26, 2010 - 12:22 PM
- - Spider77   Everything hooked all back up to stock....I'll...   Oct 26, 2010 - 7:43 PM
- - 4-eyed-freek   awsome spider77 im looking forward to seeing these...   Oct 26, 2010 - 9:31 PM
- - Spider77   I updated the first post with numbers. I am in no...   Oct 27, 2010 - 5:53 PM
- - hatchy_gt-s   The only prob. is thats the temp. of the throttle ...   Oct 28, 2010 - 11:22 AM
- - Spider77   Yes, I know this. That was the whole point of the...   Oct 28, 2010 - 4:46 PM
- - Bitter   if it really made any difference, you'd think ...   Oct 28, 2010 - 9:30 PM
- - Spider77   Hell, I see a lot of stuff that dosent make sense,...   Oct 29, 2010 - 5:20 AM
Lo-Fi Version Time is now: August 29th, 2026 - 6:07 AM
