Oct 22, 2010 - 11:47 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
i found this pic that gives you an idea if anyone is looking to do a throttle body coolant bypass. i found it helpful so i hope it helps you guys.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
4-eyed-freek coolant bypass pic. Oct 22, 2010 - 11:47 AM
Robbie1902 How do you go about doing this and what are the be... Oct 24, 2010 - 12:28 PM
Johnnyny QUOTE (Robbie1902 @ Oct 24, 2010 - 1... Oct 24, 2010 - 1:21 PM
Robbie1902 No i know that im just asking how to do it and whe... Oct 24, 2010 - 1:39 PM
4-eyed-freek where it says iac in the pic. take the two lines t... Oct 24, 2010 - 3:42 PM
Robbie1902 Haha thanks i looked at the pic again and was like... Oct 24, 2010 - 4:02 PM
4-eyed-freek yup no problemo. Oct 24, 2010 - 4:42 PM
luka know what size fitting that is? Oct 24, 2010 - 7:09 PM
4-eyed-freek i used a 3/8. its was a really good fit. make sure... Oct 24, 2010 - 7:17 PM
4-eyed-freek this is why i say do this when the engine is cool.... Oct 24, 2010 - 7:25 PM
Remy The only REAL benefit you gain from capping off th... Oct 24, 2010 - 7:43 PM
azian_advanced there is no gain in power by removing the throttle... Oct 24, 2010 - 8:03 PM
Robbie1902 It will help with heat tho, the less heat in the t... Oct 24, 2010 - 8:59 PM
Bitter QUOTE (azian_advanced @ Oct 24, 2010 - 9... Oct 24, 2010 - 9:41 PM
hatchy_gt-s YAY!!! Someone actually knows common s... Oct 24, 2010 - 10:16 PM
Spider77 Since we've gotten into this, I really want to... Oct 25, 2010 - 6:33 PM
Hanyo Just a warning to those who live where it snows. D... Oct 26, 2010 - 1:28 AM
4-eyed-freek how would it get frozen if there is not liquid in ... Oct 26, 2010 - 10:05 AM
Spider77 Ok, so today at lunch, I took some temp readings (... Oct 26, 2010 - 12:22 PM
Spider77 Everything hooked all back up to stock....I'll... Oct 26, 2010 - 7:43 PM
4-eyed-freek awsome spider77 im looking forward to seeing these... Oct 26, 2010 - 9:31 PM
Spider77 I updated the first post with numbers. I am in no... Oct 27, 2010 - 5:53 PM
hatchy_gt-s The only prob. is thats the temp. of the throttle ... Oct 28, 2010 - 11:22 AM
Spider77 Yes, I know this. That was the whole point of the... Oct 28, 2010 - 4:46 PM
Bitter if it really made any difference, you'd think ... Oct 28, 2010 - 9:30 PM
Spider77 Hell, I see a lot of stuff that dosent make sense,... Oct 29, 2010 - 5:20 AM![]() ![]() |
| Lo-Fi Version | Time is now: July 8th, 2026 - 3:58 AM |
