> Throttle Body Coolant Bypass (with pics), Want to bypass the coolant flow to your Throttle Body on you 5SFE?
post Oct 24, 2010 - 7:57 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
So, after quite a few PM's on how to do this I finally broke down and took some pics. You will notice however that I did not put everything back to "factory settings", ie, I just took a few pictures and hope that they'll help the ones who want to know how to do this.
First off though, a warning:
****THE COOLANT WILL BE HOT AFTER RUNNING THE ENGINE, THEREFORE TO AVOID BURNS I STRONGLY SUGGEST THAT YOU LET THE ENGINE/COOLANT SYSTEM COOL DOWN BEFORE ATTEMPTING TO DO THIS, I AM IN NO WAY RESPONSIBLE FOR PERSONAL HARM THAT MAY BE CAUSED WHILE ATTEMPTING THIS, YOU HAVE BEEN WARNED****
STEPS:
1:) You want to start by disconnecting your SRI/CAI/Stock Intake at the throttle body:
2:) Disconnect the 4 Vac lines (three on top, one that sits lower):
3:) Disconnect the Throttle Cables (one for Man, two for Auto):
4:) Remove TB by pulling the 4 12 mm bolts:
5:) Remove TB from Intake Plenum:
6:) You will notice three lines hooked into the TB, two outside line (coolant) and one middle line (vac). You want to "bypass" the TB by linking the two coolant lines together, using a 5/16th brass bard (male to male) fitting and screw clamps to tighten it down. Please do not use existing hardware as its probably been sitting there for a while and chances are it wont stand up. Please use new hardware (screw clamps).
7: After you insert brass barb (male to male fitting) and tighten down the screw clamps, you might want to install some vac caps on the coolant ports. Although I cant say if its required, for me its just piece of mind):
8: Reattach the Vac line (its the middle port)!
8.5: Totally optional, but at this time I did a minor cleaning of the TB, and the butterfly valve. Not required, but while its open, might as well, right?
9: Check your work. This is what you should have, two coolant lines "looped" together, two coolant ports capped (optional), and the Vac line (the middle port) reattached. Make sure that your screw clamps are tight (either use a socket or the right size four point to make sure its super tight...don't want leaks), and again, check another time. Once you are sure everything is done, place your throttle body back on the intake plenum, place the SRI/CAI/Stock Intake back on, and enjoy!
While I can not say this is how it is for different engines, the concept is the same. So, for all those people PM'ing me, this is how you do it (again ,mind you its not a pure step by step, but you'll get the idea), and for those who want to know how to TB Bypass on the 5SFE, here you go!
I hope this can help answer this question to some extent. If anyone sees anything wrong with this (ie mislabeling please let me know so I can correct).
Thanks and hope you enjoy!
- Spider77   Throttle Body Coolant Bypass (with pics)   Oct 24, 2010 - 7:57 PM
- - Robbie1902   Very nice write up!   Oct 24, 2010 - 8:27 PM
- - mkernz22   vote for sticky!   Oct 24, 2010 - 8:41 PM
- - 4-eyed-freek   sticky!   Oct 24, 2010 - 8:56 PM
- - hatchy_gt-s   Not to sound like a dick but those are there for a...   Oct 24, 2010 - 10:28 PM
- - 4-eyed-freek   i just dont understand why toyota would run coolan...   Oct 24, 2010 - 11:06 PM
- - Spider77   Well, the one reason why I had it set up like this...   Oct 25, 2010 - 5:22 AM
- - sphinxxx   sorry for the newb question, but what is this for ...   Oct 26, 2010 - 1:25 PM
|- - 4-eyed-freek   coolant runs through your throttle body making it ...   Oct 26, 2010 - 9:36 PM
|- - Langing   QUOTE (4-eyed-freek @ Oct 26, 2010 ...   Oct 1, 2014 - 8:03 AM
- - fgvillegas   i was thinking if the effects of doing this will b...   Oct 27, 2010 - 12:28 AM
- - Akirad1   i have to agree with spider77 since we live in Tex...   Oct 30, 2010 - 9:16 AM
|- - Langing   QUOTE (Akirad1 @ Oct 30, 2010 - 10:1...   Sep 9, 2014 - 11:26 AM
- - Tom_SS2   it's not meant to heat the intake as such it...   Oct 30, 2010 - 9:22 AM
- - doory100   Main question is there any gain in doing this?   Sep 9, 2014 - 4:20 PM
|- - Langing   QUOTE (doory100 @ Sep 9, 2014 - 5:20...   Sep 9, 2014 - 8:36 PM
- - Bitter   Nothing that can be measured reliably.   Sep 9, 2014 - 7:39 PM
- - Bitter   It's there to prevent icing of the throttle pl...   Sep 9, 2014 - 9:53 PM
- - VavAlephVav   I examined the Idle Speed Control Valve when I had...   Sep 9, 2014 - 9:59 PM
- - VavAlephVav   QUOTE (Spider77 @ Oct 24, 2010 - 8:5...   Sep 9, 2014 - 10:09 PM
- - Bitter   It may just be a coil spring to make sure the IAC ...   Sep 9, 2014 - 10:50 PM
|- - Langing   QUOTE (Bitter @ Sep 9, 2014 - 11:50 ...   Sep 12, 2014 - 12:08 PM
- - VavAlephVav   it is definitely set up in a slot-n-groove sort of...   Sep 9, 2014 - 11:21 PM
- - VavAlephVav   yeah, the center tube on the bottom of the throttl...   Sep 12, 2014 - 4:11 PM
- - Smaay   guys the reason there is coolant going through the...   Sep 12, 2014 - 6:57 PM
|- - Langing   QUOTE (Smaay @ Sep 12, 2014 - 7:57 P...   Sep 12, 2014 - 11:04 PM
- - Bitter   Smaay is correct, but what is the purpose of the s...   Sep 12, 2014 - 9:53 PM
- - Syaoran   The spring is actually a bimetal spring and the te...   Sep 12, 2014 - 10:40 PM
- - Bitter   Ford IAC's are easy to work with also, but the...   Sep 12, 2014 - 10:54 PM
- - Bitter   Pressure drop causes the air to condense and cool ...   Sep 13, 2014 - 12:20 AM
|- - Langing   QUOTE (Bitter @ Sep 13, 2014 - 1:20 ...   Sep 13, 2014 - 7:06 AM
- - Bitter   Low temperature but high humidity. Say when it...   Sep 13, 2014 - 10:33 AM
|- - Langing   QUOTE (Bitter @ Sep 13, 2014 - 11:33...   Sep 13, 2014 - 9:42 PM
- - Smaay   toyota makes cars that are sold all over the world...   Sep 13, 2014 - 1:07 PM
- - Bitter   My opinion is that the possible gain is so tiny an...   Sep 13, 2014 - 2:01 PM
- - Spider77   My idle is fine. And my car hasnt exploded.   Sep 13, 2014 - 6:13 PM
- - Bitter   Yes, and you live in a generally very warm and dry...   Sep 13, 2014 - 7:20 PM
- - Spider77   Actually last winter we got a good deal of ice and...   Sep 13, 2014 - 8:21 PM
- - Bitter   The odds of it happening are fairly slim since hea...   Sep 13, 2014 - 8:49 PM
- - Syaoran   I'm about to reconnect mine onto my TB. I...   Sep 14, 2014 - 5:16 PM
- - Bitter   I'll bet it makes no discernible difference.   Sep 14, 2014 - 7:57 PM
- - VavAlephVav   this is what I was unsure of at first, but now I...   Sep 14, 2014 - 11:11 PM
Lo-Fi Version Time is now: August 26th, 2026 - 8:53 AM
