> Does anyone know if a rev2 engine water pump (st185) fits a rev3 engin, Need help buying a water pump mines making a kind of grinding/knocking
post Oct 25, 2010 - 6:24 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
I'm hearing a knocking/grinding sound coming from my top timing cover. I'm assuming its my water pump, It's much easier to locate a St202 or St185 or even a MR2 turbo water pump, but the st185 has the rev 2 engine and the mr2's thats available, and the st202 has the 3s engine but its none turbo,
has anyone tried fitting a pump from any of these to the rev3 engine (st205) please help frown.gif
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
Replies (1 - 8)
post Oct 25, 2010 - 6:28 PM
Culpable04
Joined Apr 17, '06
From New Jersey
the pump itself is the same, the housing is different, so buy a ST185 pump without housing and swap the housing from your ST205 old setup, that's what I did
post Oct 25, 2010 - 6:44 PM
cax_11
Joined Aug 15, '10
QUOTE (Culpable04 @ Oct 25, 2010 - 7:28 PM) *
the housing? I thought it was all in one piece. Do you have any photos of the process? Is it easy to swap?
Nevis, West Indies
post Oct 25, 2010 - 7:14 PM
Culpable04
Joined Apr 17, '06
From New Jersey
it's easy, I don't have pictures but no, it's not one piece, the pump shoud come with a gasket that you'll need, but is easy, unbolt the pump from the housing, replace the gasket and bolt the new pump, done.
post Oct 25, 2010 - 8:04 PM
cax_11
Joined Aug 15, '10
QUOTE (Culpable04 @ Oct 25, 2010 - 8:14 PM) *
Thanks alot man! Will be ordering a st185 pump then, and just unbolt smile.gif
Nevis, West Indies
post Oct 25, 2010 - 8:10 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (Culpable04 @ Oct 25, 2010 - 6:28 PM) *
x2
Here is a 4th gen water pump housing (left) next to the other gen water pump housing(usdm MR2 so i guess 2nd gen?)
as u can see housings are different HOWEVER...
i got the brand new housing from toyota sitting around...
post Oct 25, 2010 - 9:45 PM
cax_11
Joined Aug 15, '10
QUOTE (easternpiro1 @ Oct 25, 2010 - 8:10 PM) *
x2
yep, I'm happy for that biggrin.gif ... gonna order my new pump this week, um.. another thing, is there any other rear brake pad compatible with the st205's?? cause I can't seem to get any around here and the closest place that have is in the U.K and I'm in the west indies, so shipping kills
Nevis, West Indies
post Oct 26, 2010 - 2:22 AM
Johnnyny
Joined Apr 28, '09
From York pa
supra twin turbo will work
post Oct 26, 2010 - 7:02 AM
cax_11
Joined Aug 15, '10
QUOTE (Johnnyny @ Oct 26, 2010 - 3:22 AM) *
Thanks alot smile.gif ...but is it JZA80 or JZA70??
Nevis, West Indies
Lo-Fi Version Time is now: August 31st, 2026 - 6:32 AM
