Oct 27, 2010 - 7:45 PM
Enthusiast ![]() ![]() Joined Jan 28, '09 From Austin, TX Currently Offline Reputation: 0 (0%) |
We did some custom work on a local alltrac over the last couple weeks and I wanted to see if you guys would be interested in any of this stuff if we were to make them production items.
* Custom symetrical desing oil catch can & coolant overflow. Oil catch can is built with proper internals (baffled & insulated). The coolant overflow is built as a functional but "stealth" setup. The inlet is at the bottom/front and the outlet is underneath with a long tube welded inside all the way to the top. Kinda hard to explain but you can see it in the pics. 4" intake including the proper ports for the IAC, catchcan, temp sensor (if you want the ports): Custom wastegate actuator bracket to allow the turbo to be clocked downward: Custom molded upper radiator hose to delete the ridiculous stock one that has the metal eblow in there, along with a custom nipple to use as your water feed for your turbo (if you still need it). -------------------- |
Oct 27, 2010 - 7:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
if the prices are reasonable you will have lots of interest
i wouldnt mind a 4" intake with that filter -------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Oct 27, 2010 - 7:53 PM
if the prices are reasonable you will have lots of interest i wouldnt mind a 4" intake with that filter The prices will definitely be reasonable. Those filters are nice huh? -------------------- |
Oct 27, 2010 - 10:12 PM
![]() Enthusiast ![]() ![]() Joined Nov 4, '06 From Medicine Hat, AB Currently Offline Reputation: 2 (100%) |
would definitely be interested in some if not all products shown.
-------------------- current project: looking :(
Oct 28, 2010 - 1:51 AM
Enthusiast ![]() Joined Feb 6, '08 From Latvia Currently Offline Reputation: 0 (0%) |
as i understand clocking a turbo is not a lock type position for everyone, so it has different angles, depending on the builder, probably not more than 30 degrees from block to radiator. how do you overcome this problem? or the wastegate actuator is not so sensible to position and angle?
catch can is superb -------------------- 1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ |
Oct 30, 2010 - 12:36 PM
as i understand clocking a turbo is not a lock type position for everyone, so it has different angles, depending on the builder, probably not more than 30 degrees from block to radiator. how do you overcome this problem? or the wastegate actuator is not so sensible to position and angle? catch can is superb There's really not much room for various angles when clocking it downward. Too far this way and you're too close to the clutch slave cylinder. Too far the other way and you're too close to the radiator. Where we clocked it is pretty much the perfect spot for it to be for the best entry angle for the pipe connected to the compressor outlet. -------------------- |
Nov 1, 2010 - 5:39 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
The 4in intake would be awesome, as it seems some of the UK sellers dont even want to try to ship merchandise like that to america. Basically it would be nice to have it marketed to those in america and other countries outside the UK.
Also, it seems the catch cans are geared towards the 185. Would it be possible to use it for the 205 engine bay as well? -------------------- (\__/)
Nov 1, 2010 - 6:28 AM
just like i posted elsewhere, the intake wont fit on a 6gc with cruise or a battery in the stock location, the catch cans are in the fuse box and ABS locations.
Nov 1, 2010 - 10:29 AM
just like i posted elsewhere, the intake wont fit on a 6gc with cruise or a battery in the stock location, the catch cans are in the fuse box and ABS locations. One glance at an engine bay and I think that's a given. Certain items fit with certain components. Certain items don't. We've already made the custom brackets to relocate the fusebox & relaybox as pictured above. Most guys are relocating their batteries to the rear already, and if there are folks that want to keep their battery in the front, we can make an intake that will fit for those folks as well. -------------------- |
Nov 1, 2010 - 3:09 PM
just like i posted elsewhere, the intake wont fit on a 6gc with cruise or a battery in the stock location, the catch cans are in the fuse box and ABS locations. One glance at an engine bay and I think that's a given. Certain items fit with certain components. Certain items don't. We've already made the custom brackets to relocate the fusebox & relaybox as pictured above. Most guys are relocating their batteries to the rear already, and if there are folks that want to keep their battery in the front, we can make an intake that will fit for those folks as well. i understand that, but, the "relocation" of parts on a 5th gen isnt the same as a 6gc, our engine bays are layed out a bit diffrently,(ie fuse boxes are in diffrent locations, ect) and i was just making sure you were aware. -------------------- Former Team 5SFTE pro member ;)
Nov 2, 2010 - 6:36 PM
just like i posted elsewhere, the intake wont fit on a 6gc with cruise or a battery in the stock location, the catch cans are in the fuse box and ABS locations. One glance at an engine bay and I think that's a given. Certain items fit with certain components. Certain items don't. We've already made the custom brackets to relocate the fusebox & relaybox as pictured above. Most guys are relocating their batteries to the rear already, and if there are folks that want to keep their battery in the front, we can make an intake that will fit for those folks as well. i understand that, but, the "relocation" of parts on a 5th gen isnt the same as a 6gc, our engine bays are layed out a bit diffrently,(ie fuse boxes are in diffrent locations, ect) and i was just making sure you were aware. Yup... we can always make more intakes and catchans with various designs for the different generations as long as there's interest to justify the time/expense. -------------------- |
| Lo-Fi Version | Time is now: August 28th, 2026 - 8:43 AM |
