Nov 3, 2010 - 6:23 PM
Enthusiast ![]() ![]() Joined Jan 22, '09 From Fort Worth, Texas Currently Offline Reputation: 3 (100%) |
I need some advice on possibly a bad brake master cylinder? I'm onto something here I think!
I have noticed periodically when I apply consistent pressure while braking, the pedal will start to go soft and sink to the floor almost and I have to reapply pressure to avoid rolling forward/backwards. I have had all my brake lines checked for leaks and also had a brake fluid flush done and I'm still noticing it happening every now and then. I have also checked the firewall inside the car for leaks and underneath the hood only to find nothing out of the ordinary. Now for my stupid question, the braking hydraulic system is it's own system away from the clutch slave & master in our cars correct? There is only a Master Brake Cylinder and nothing else? Basically how I'm looking at it is -Clutch Master & Slave Cylinders (It's own system) -Brake Master Cylinder (No Slave Cylinder)? I apologize in advance if I sound repeating or if I'm over thinking what I'm really trying to say. Just would like some input please & thank you! This post has been edited by Hazmat: Nov 4, 2010 - 12:36 AM |
Hazmat Losing Braking Pressure Nov 3, 2010 - 6:23 PM
Spider77 Typically "spongy" brake response means ... Nov 3, 2010 - 6:31 PM
Hazmat The bleeders are tight and I'm still seeing no... Nov 3, 2010 - 6:52 PM
presure2 yup, sounds like a bad master,(there is no "s... Nov 4, 2010 - 8:54 AM
blu94gt I just replaced a bad master cylinder on a friend... Nov 5, 2010 - 10:52 AM
Hazmat Thanks for the help guys! I took it out again ... Nov 7, 2010 - 1:19 AM![]() ![]() |
| Lo-Fi Version | Time is now: June 23rd, 2026 - 1:17 PM |
