Nov 5, 2010 - 8:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
So it's going to be my first winter with this car...
How good or bad is it in the snow? I just want to get myself prepared for it haha |
Nov 5, 2010 - 8:42 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
winter driving in a celi isn't too bad.
Just make sure you have good tires LOL. I've been driving in the cold wisconsin winters for 4-5 years and I have no problems. We measure our snow in FT not INCHES -------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Nov 5, 2010 - 8:46 AM
as long as you have good all season tires, you'll be fine, mike.
just drive slower, and give pleanty of room between cars. the celica isnt too bad at all in the snow, till you lower it and put wider summer tires on it, then it dont move. -------------------- Former Team 5SFTE pro member ;)
Nov 5, 2010 - 9:03 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
it helps to use engine braking or engine compression in conjunction with lightly using the brakes to avoid slipping over a patch of ice.
surprisingly the car is good in snow imo. it handles well through turns in the sense that the nose of the car stays pointing in the right direction (in most cases) and doesn't spin out unlike rwd cars. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Nov 5, 2010 - 9:28 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
I thought the celica did awesome in the snow last year, im running 205's, only problem i had was stopping lol, but it did well, i even had it through 6 inches of snow, always started in second gear though, not sure about this year, little lower now so we will see
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Nov 5, 2010 - 10:57 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
I've always been a fan of the Celica during the winter, but like has been said make sure your tires are good. Any car with good tires will get you around though, people who say a certain car sucks in the snow either doesn't know how to drive or doesn't have good tires on it.
Tidbit of info if you don't know already. Make sure your rear tires are the ones with more tread (if they aren't all evenly worn). It may seem like you want more on the front tires to grip, but the rears are what determines your line of travel. If you have tires with less tread on the rear then the rear will drift around. I tried once when I heard this in tech-school because I didn't believe it, it was like driving with 2 slicks on the back the ass-end slid all over the place. -------------------- 1999 Celica GT
Nov 5, 2010 - 11:24 AM
Enthusiast ![]() ![]() Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
celicas are really good in the snow. but bc they are so light, you run into the same problem u have with rain: they handle great at lower speeds. if u try to fly down a road full of slush, ur car will get raped by the tracks left by other vehicles. like azian said, use engine break if u can. also do not try to slide around corners if u are not experienced with this yet. bc if u do u will slide into a tree or something like i did when i was 16
Nov 5, 2010 - 9:54 PM
Good thing is I had my tires replaced about 2k ago so they are pretty much brand new
I'll just take it easy and stay back from other cars. Never heard of it before, but engine braking is?.... Also, I'm just still scared to drive in the snow because of my first accident in the Acura when I lost control going around a corner doing 20mph. It wasn't sharp either, but the rear-end just went out on me. The only reason it was so bad is the fact that I tried to correct it, but kept over correcting, and I finally got stuck in a slide. I picked up speed as I was swerving because I was trying to power out a little, but I over did it. When I got stuck in the slide, I floored it because I was trying to go back the other way, but it just stayed. And boom. Telephone pole whack to the front end |
Nov 7, 2010 - 7:18 AM
Good thing is I had my tires replaced about 2k ago so they are pretty much brand new I'll just take it easy and stay back from other cars. Never heard of it before, but engine braking is?.... Also, I'm just still scared to drive in the snow because of my first accident in the Acura when I lost control going around a corner doing 20mph. It wasn't sharp either, but the rear-end just went out on me. The only reason it was so bad is the fact that I tried to correct it, but kept over correcting, and I finally got stuck in a slide. I picked up speed as I was swerving because I was trying to power out a little, but I over did it. When I got stuck in the slide, I floored it because I was trying to go back the other way, but it just stayed. And boom. Telephone pole whack to the front end engine braking is when you let off the gas, leaving the car in gear, allowing the engine to slow you down. -------------------- Former Team 5SFTE pro member ;)
Nov 7, 2010 - 9:50 AM
ohhhhh i gotchaa haha
Nov 8, 2010 - 12:50 AM
Enthusiast ![]() ![]() Joined Apr 8, '09 From Montréal, Québec Currently Offline Reputation: 2 (100%) |
![]() ![]() Tell me about winter driving in the celi Toyo winter tires are your friends This post has been edited by trebilihp: Nov 8, 2010 - 12:52 AM -------------------- -PHILI- ![]() |
Nov 8, 2010 - 9:55 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
i use dunlop's studless winter tires. they work very well!
This post has been edited by 4-eyed-freek: Nov 8, 2010 - 9:56 AM -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Nov 8, 2010 - 9:59 AM
i have the dunlop direzza tires, they have great traction in the rain and on dry pavement!
just have to find out how well they are in the snow now |
Nov 8, 2010 - 11:33 AM
I might be wrong but direnza aren't winter tires... So, they won't do a good job if there's alot of snow and ice where you live. I personally use toyo observe go2 plus and they are great for city driving, cause they're more ice tores than snow tires.. But overall, i just love those tires compared to anything i drove before. If i can give you only one advice, if you wanna do great in winter driving, a good set of WINTER tires is essential, or youre gonna end up having trouble in a curve at only 20mph...
Nov 8, 2010 - 1:25 PM
i have the dunlop direzza tires, they have great traction in the rain and on dry pavement! just have to find out how well they are in the snow now Those are summer tires. You're not going to get much of anywhere in the snow. May want to look at replacing them or start browsing craigslist for a set of steelies with all seasons or snow tires. -------------------- 1999 Celica GT
Nov 8, 2010 - 3:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
celi is greattt in the snow! (with decent tires obviously)
My driveway...is a parking lot, and me and my cousin screw around in it all the time, hard a hard time making the celi loose control (when i was trying to lol) camaro... on the other hand... dont drive one of those hahaa -------------------- |
Nov 8, 2010 - 7:01 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
i use dunlop's studless winter tires. they work very well! and not too bad on the curvys on "71" on dry pavement -------------------- |
Nov 9, 2010 - 7:47 PM
very true. if you were to use them as an all year tire they would be ok, just the life of them in the hot summer would be nasty! but otherwise they are the best winter tires i have had on the car!
Nov 9, 2010 - 8:01 PM
Enthusiast ![]() ![]() Joined Oct 24, '09 From Appleton, Wisconsin 54915 Currently Offline Reputation: 7 (100%) |
Last snow season i didn't have any money to replace my tires so i ended up driving on "slicks". To my surprise, the celica still handled better than i had expected. This year im driving on Kuhmo ectsa asx all seasons and havent seen a snow flake yet.
Nov 9, 2010 - 8:14 PM
yea appleton probably hasnt seen snow yet, but my mom called and said that they were getting some snow in menominee, but it was sticken to the ground.
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:25 PM |
