Nov 5, 2010 - 7:39 PM
Enthusiast ![]() ![]() Joined Jan 17, '06 From Wisconsin Currently Offline Reputation: 0 (0%) |
Hello I just swapped my rear brake pads and rotors for new ones on my 94 gt. One side turned out like brakes normally do new, the wheel turns by hand with a little resistance. The other side is a different story. I could not turn the wheel with both hands at all and I had to pound the caliper to get it on even though I had the piston pressed in all the way. I tried the old rotor and it was the same so its not the new rotor.
-Can a poorly made set of brake pads cause this from being too thick? -It looks like the outside pad is too thick, that's my guess.... I got the pads from rock auto so I can't just take em back..... -ANyone experienced something similar? thanks, Brandon |
bdog_v rear brake job? Nov 5, 2010 - 7:39 PM
al94st Have you put the car on the ground and tried the b... Nov 5, 2010 - 9:34 PM
cyberblader1130 Check the slides on the caliper. They could be se... Nov 5, 2010 - 9:47 PM
bdog_v Thanks for the replies guys. the car is not going ... Nov 5, 2010 - 10:15 PM
cyberblader1130 what your thinking about is a fixed caliper. we ha... Nov 5, 2010 - 10:39 PM
bdog_v Good call I just went outside and tried to pull th... Nov 5, 2010 - 11:03 PM
bdog_v Well I just priced caliper brackets they are like ... Nov 5, 2010 - 11:13 PM
cyberblader1130 QUOTE (bdog_v @ Nov 5, 2010 - 11:13 ... Nov 6, 2010 - 1:56 PM
bdog_v Hi there, I'm way north of appleton. Otherwise... Nov 6, 2010 - 7:33 PM![]() ![]() |
| Lo-Fi Version | Time is now: June 23rd, 2026 - 9:47 AM |
