Nov 12, 2010 - 8:11 AM
Enthusiast Joined Jan 24, '08 From Russia,Moscow Currently Offline Reputation: 0 (0%) |
Hi all. The question is the thread size of gearbox oil cooler. I install front mount IC and want to relocate gearbox cooler and replace non flexible hoses to stainless steel flexible ones. So i need to know fitting thread sizes to make stainless steel lines. Maybe somebody has all ready done this operation and know thread sizes. So please help, i have already searched forums, but found nothing.
This is what i am talking about: ![]() Best regards, Sergei. This post has been edited by JDM_Rider: Nov 12, 2010 - 8:11 AM -------------------- |
Nov 12, 2010 - 2:09 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
best to get in touch with TRDGT4, he has done alot of work in this area
TRDGT4 build (installing oil coolers part) -------------------- |
Nov 12, 2010 - 3:45 PM
Thanks, i will try to ask him
May 21, 2012 - 11:12 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
Sorry for bringing an old thread back to life, but does anybody happen to know the answer to the original question?
I am in the process of installing a FMIC and need to relocate my transmission oil cooler and want to get braided hoses from the transmission to the cooler. -------------------- |
May 21, 2012 - 1:07 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
I got fittings from summit, but I just ran rubber lines as i'm using the oil cooler from my rx7 that I dont use anymore and it has barbed connections. The lines are not high pressure.
-------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
May 22, 2012 - 8:58 AM
I got fittings from summit, but I just ran rubber lines as i'm using the oil cooler from my rx7 that I dont use anymore and it has barbed connections. The lines are not high pressure. Do you know what size the fittings were? That is what I am interested in knowing so I can order some braided hose. I believe it is M14 x 1.5 on the transmission itself and am wondering if the cooler is the same or if it is -an or NPT fitting? This post has been edited by WALKER: May 22, 2012 - 8:58 AM -------------------- |
May 22, 2012 - 10:01 AM
I got fittings from summit, but I just ran rubber lines as i'm using the oil cooler from my rx7 that I dont use anymore and it has barbed connections. The lines are not high pressure. Do you know what size the fittings were? That is what I am interested in knowing so I can order some braided hose. I believe it is M14 x 1.5 on the transmission itself and am wondering if the cooler is the same or if it is -an or NPT fitting? http://www.summitracing.com/parts/HDT-PS-030/ If it's an OEM cooler then its not AN for sure. Have you made braided lines before? They are a pain in the ass. Could just buy that fitting, then -6an to barb. NPT to barb for the cooler; run some cheap fuel line hose with some clamps. If you've made the lines before then it won't hurt, just more expensive and not really necessary. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
| Lo-Fi Version | Time is now: May 28th, 2026 - 12:37 AM |
