Nov 14, 2010 - 12:16 PM
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
So I was driving and my oil light started blinking, few minutes later, I started hearing this weird grinding/knocking sound at high rpms so I slowed down to around 50
Then I put the car In nuetral and reved up, sane sound I lost some power and the the car shut off, I thought I ran out of gas so I filled few gallons in (I luckily stoped in front of a shell) Started it up and hears LOUD squeaking along with the knock, Checked my oils and i was OUT/EMPTY So I put in 4 quarts of "golden state sae 30" (that's all they had) Drove it to my work and now my car stopped squeaking but still hear a knock! The oil is 'dirty but full' .... What could it be? No oil leaking from the bottoms, muffler is dry nothing out of the ordinary beside the knock Keep in mind that I rebuild the engine 5000 miles ago so could it be that I messed up somewhere? And after the rebuild, I didn't change the oil until 1300 miles like the Haynes manuel said This post has been edited by Malhar95: Dec 3, 2010 - 1:06 PM -------------------- For Sale:OEM tail lights - make offer
Nov 14, 2010 - 12:58 PM
sounds like you wrecked the bottom end again by running it with no oil.
Nov 14, 2010 - 10:15 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
Nov 15, 2010 - 1:34 AM
you spun a rod or main bearing. your crank is toast. if you spun a main then you need the mains line honed. it will almost be cheaper to get a new shortblock if thats the case.
Nov 15, 2010 - 7:43 PM
so its a high chance that i need to replace my bearings??
if thats the case, do i have to rebuild the motor again, or can i just lift the car up, take the oil pan off and work from the bottom? -------------------- For Sale:OEM tail lights - make offer
Nov 15, 2010 - 7:51 PM
Enthusiast Joined Nov 15, '10 From MA Currently Offline Reputation: 0 (0%) |
so its a high chance that i need to replace my bearings?? if thats the case, do i have to rebuild the motor again, or can i just lift the car up, take the oil pan off and work from the bottom? I spun a couple bearings once and just had the crank turned and polished again. I had to pull the engine though to get to the rod bearings. Replaced them, refinished the crank, and then sold the car in perfect running order a couple years later. Not too sure in your case but it seems quite possible. Also, it seems like you did spin a bearing...at least. If you decided to tear into it again, just check the oil pump to make sure it didn't get chewed up. |
Nov 15, 2010 - 8:24 PM
but how can my bearings go bad so fast?
i rebuilt the engine 3000-5000 miles ago -------------------- For Sale:OEM tail lights - make offer
Nov 15, 2010 - 9:20 PM
Enthusiast ![]() Joined Apr 6, '09 From Mass Currently Offline Reputation: 0 (0%) |
because you ran it without oil.
Nov 16, 2010 - 10:36 PM
Nov 16, 2010 - 11:29 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
Im sorry but why didnt you think that you should have pulled over when your oil light started to flicker??? usually when its that light it means your oil is low/ you have no oil pressure
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Nov 17, 2010 - 1:10 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
Im sorry but why didnt you think that you should have pulled over when your oil light started to flicker??? usually when its that light it means your oil is low/ you have no oil pressure People never seem to learn that when the oil light comes on, it means shut the car off that very instant. It's not just a low oil light. -------------------- 1999 Celica GT
Nov 23, 2010 - 8:03 PM
oh cuz my brother was driving it to work with me on the passenger...he told me abt the light AFTER i was stopped at a gas station
Nov 24, 2010 - 4:32 PM
operator error, you can only blame your brother and yourself then. the light comes on for a reason. your fault for letting it get that low.
it is possible to have the crank turned and then use oversized bearings. but you can NOT just throw in a new set of bearings. that journal MUST be perfectly polished. when the bearing spun, that means the bearing bonded with the crank and spun in the rod. you really should replace the rod, and teh crank or you take a chance of it happening again -------------------- 2001 Celica GT-S Turbo
Nov 24, 2010 - 11:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
so what does it mean if your oil light comes on for a second or two when you turn the car on? I recently noticed this happening.
Nov 25, 2010 - 12:34 AM
So I was driving and my oil light started blinking, few minutes later, I started hearing this weird grinding/knocking sound at high rpms so I slowed down to around 50 Then I put the car In nuetral and reved up, sane sound I lost some power and the the car shut off, I thought I ran out of gas so I filled few gallons in (I luckily stoped in front of a shell) Started it up and hears LOUD squeaking along with the knock So the story changes now? so what does it mean if your oil light comes on for a second or two when you turn the car on? I recently noticed this happening. This usually happens in the cold but really does not matter what time of year it is, its just low oil pressure on start up, takes a minute for the system to pressurize, mine does it too, your good as long as it does not stay on -------------------- 1996 Toyota Celica Project Mean Green
Nov 25, 2010 - 8:39 PM
Enthusiast ![]() Joined Oct 28, '08 From CT Currently Offline Reputation: 0 (0%) |
Omfg this thread is ****ing epic!!! Umm how can your bearing go bad so fast??? Hmm try re reading your initial post you checked the oil and you were bone dry, let alone after you saw the oil light go on you slowed down put it in neutral and reved the engine. What would posses you to do that? Im sry bro but your engine is ****ed, as soon as you saw the light you should of stopped the car immediatly and added oil, and even then its prob still too late. Please never rev your engine when you see an oil light go on again. Also these cars are 10-15 years old now they burn/leak oil you should atleast be checking your oil once every week or 2...oil is most important thing for your engine.
-------------------- 96 Celica gt 5 spd 218k intake, header, rear strutbar, new clutch...again :/
02 Saab 9-5 silver Aero 5 speed 150k w/ 80k mile engine, new clutch, k&n intake, turbos xs bov 92 sandstone grey 3000gt vr4 upgraded turbos, turboback exhaust, intake, mbc, walbro 91 black 3000gt vr4 needs work stock turbos |
Nov 30, 2010 - 10:40 PM
well im aware that i did mess up, even though i wasnt the one driving, i should have done something...
but rite now my problem isnt 'whos fault was it' its 'what should i do? and would could be wrong' here's a quick video i took that day. ![]() few more questions i have: 1. if i have to change the bearings, can i do them from the bottom? and ifso, how (a quick step by step process)? 2. would it be cheaper if i just buy a used engine? note: i called up the place where i got the parts for my previous rebuild, and they said that they can replace all the parts that failed for free so i wont have to buy new ones. -------------------- For Sale:OEM tail lights - make offer
Dec 3, 2010 - 1:04 PM
so i knw for a FACT, that its a rod knocking,
could this mean that the rod is bent or damaged? or just the bearings? can i do the repairs without taking it apart? like from the bottom? please need help asap -------------------- For Sale:OEM tail lights - make offer
Dec 5, 2010 - 9:12 PM
you CAN replaace bearings by taking the ol pan off, but its recommended you pull the crank and have it turned down, because if the car was driven any significant distance theres a good chance the journals were gouged
again if the car was driven much you may have bend a rod, knocking is very stressful on the engine. and if you keep driving it may let the rod go = new engine -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Dec 6, 2010 - 12:16 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
ah dang man! sorry to hear the news! idk how much it costs to rebuild motors, but shouldnt u be able to pick up another 5s for cheap on here? bt since youre getting replacement parts u may be ok pricewise
| Lo-Fi Version | Time is now: August 22nd, 2026 - 5:49 PM |
