> Gutted 6G hatch that could trap 150mph in the 1/4 which brake kit?
post Nov 18, 2010 - 12:02 PM
eazy2001x
Joined Feb 23, '05
as the title states...
I’m looking form something good enough for drag that would be able to stop a 800whp 94-99 body. I am looking into the Ksport front and rears and would like to use 16-17inch rims, however i need to know if there will be enough stopping power and has anyone incorporated a way to get the e-brake to work.
my options for 16 inch rims are the 11 or 12 inch kit. if i wanted to go to 15 inch rims i would have to use the 11 inch kit. But I dont know what the stock sized rotors are and if i can get away with the 11 inch kit and run 16 inch rims and there be enough stopping power i would go for it.
so my questions are:
which of the two kits would be enough to stop my car?
what are the dimensions of the stock rotors?
Thanks,
Eazy
This post has been edited by eazy2001x: Nov 18, 2010 - 2:05 PM
- eazy2001x   Gutted 6G hatch that could trap 150mph in the 1/4 which brake kit?   Nov 18, 2010 - 12:02 PM
- - azian_advanced   how fast will you be going before applying the bra...   Nov 18, 2010 - 12:14 PM
|- - eazy2001x   QUOTE (azian_advanced @ Nov 18, 2010 - 1...   Nov 18, 2010 - 12:47 PM
- - mkernz22   You could do the Supra caliper setup for the brake...   Nov 18, 2010 - 12:30 PM
|- - eazy2001x   QUOTE (mkernz22 @ Nov 18, 2010 - 1:3...   Nov 18, 2010 - 12:35 PM
- - 95CelicaST   Calipers don't have a lug pattern. If I may ...   Nov 18, 2010 - 12:49 PM
|- - eazy2001x   QUOTE (95CelicaST @ Nov 18, 2010 - 1...   Nov 18, 2010 - 12:55 PM
- - 95CelicaST   You aren't using a Supra rotor, just the calip...   Nov 18, 2010 - 1:06 PM
- - eazy2001x   i am going to run the tein flex which is what i ha...   Nov 18, 2010 - 1:15 PM
- - eazy2001x   seems that the Wilwood 13" 4 piston would be ...   Nov 18, 2010 - 1:20 PM
- - njccmd2002   RE: Gutted 6G hatch that could trap 150mph in the 1/4 which brake kit?   Nov 18, 2010 - 1:23 PM
- - eazy2001x   come on guys.. help point me in the right directio...   Nov 18, 2010 - 1:30 PM
- - Culpable04   for rears use ST205 rear brake systen, it uses the...   Nov 18, 2010 - 3:03 PM
- - eazy2001x   yes.. thats me on the Mr2oc.. Eazy2001x :-) and i ...   Nov 18, 2010 - 3:16 PM
- - presure2   you guys obviously dont know easy...he is well kno...   Nov 18, 2010 - 3:23 PM
- - eazy2001x   presure2 Thanks man.. and i think ill do what i sa...   Nov 18, 2010 - 3:36 PM
- - eazy2001x   sorry another question. do i need the ST205 rotor ...   Nov 18, 2010 - 3:56 PM
- - Culpable04   QUOTE (eazy2001x @ Nov 18, 2010 - 3...   Nov 18, 2010 - 4:10 PM
|- - eazy2001x   QUOTE (Culpable04 @ Nov 18, 2010 - 4...   Nov 19, 2010 - 8:50 AM
- - eazy2001x   are these good for the rear? http://www.rhdjapan....   Nov 19, 2010 - 10:34 AM
- - Culpable04   the picture shows front disc, but yes C-one rear s...   Nov 19, 2010 - 11:00 AM
|- - eazy2001x   QUOTE (Culpable04 @ Nov 19, 2010 - 11...   Nov 19, 2010 - 11:19 AM
- - Culpable04   these are not my pictures, these are taken from Lu...   Nov 19, 2010 - 11:41 AM
- - eazy2001x   Thank you.. you guys are the best and all the post...   Nov 19, 2010 - 11:47 AM
- - mkernz22   are you looking to spend a lot? there is some goo...   Nov 19, 2010 - 12:01 PM
- - eazy2001x   shipping is still going to kill me on thos.. its 1...   Nov 19, 2010 - 12:15 PM
- - Smaay   well being an avid drag racer. the racetrack MUST ...   Nov 23, 2010 - 9:44 AM
- - eazy2001x   i know and have read about the role cage/Para shoo...   Nov 23, 2010 - 11:39 AM
- - eazy2001x   Ok, I have been working with a company that offers...   Dec 7, 2010 - 12:47 PM
- - Culpable04   both kits will do the job for you, so I think is a...   Dec 7, 2010 - 1:57 PM
- - eazy2001x   i was thinking the same thing.. I might just go wi...   Dec 7, 2010 - 2:01 PM
- - eazy2001x   so i got some options.. standard one piece rotors ...   Dec 8, 2010 - 3:25 PM
- - playr158   i wouldn't touch anything that was drilled and...   Dec 8, 2010 - 8:50 PM
- - eazy2001x   ill just go with slotted and what is the big diff ...   Dec 9, 2010 - 12:32 AM
- - eazy2001x   oh and i got the answer for 1 vs 2 here: http://ww...   Dec 9, 2010 - 12:49 AM
- - playr158   yes advantages are weight and they run cooler, muc...   Dec 9, 2010 - 12:55 AM
- - eazy2001x   wow.. ok.. for the 4 piston fron/rear/slotted/drum...   Dec 10, 2010 - 1:57 PM
- - 95CelicaST   Wait, so now this is a 800whp daily driver/drag/tr...   Dec 10, 2010 - 2:59 PM
- - Culpable04   those 500 bucks can lighten up another section of ...   Dec 10, 2010 - 2:59 PM
- - eazy2001x   QUOTE (95CelicaST @ Dec 10, 2010 - 2...   Dec 10, 2010 - 3:20 PM
Lo-Fi Version Time is now: August 25th, 2026 - 4:39 AM
