Nov 18, 2010 - 6:07 PM
Enthusiast Joined Nov 18, '10 From Jersey City, NJ Currently Offline Reputation: 0 (0%) |
Hey guy, I'm not too familiar with Celicas as I'm more of a VW guy, but I would love some help on some issues I'm trying to diagnose. My friend just bought a 95 GT convertible. The engine runs great and it drives amazingly. However, it has this random stalling/shutting off issue and I can't seem to figure it out. Here's what happens:
The car will shut off out of nowhere. Doesn't stutter, shake, no CEL, nothing. It happens at any time, independent of temperature, weather, engine temperature. Usually will turn right back on as if nothing happens. HOWEVER, sometimes it will not turn back on. When this happens, no CEL or battery light (warning lights) will turn on when the key is turned to the on position. So where do I start? I'm thinking that the issue could be a faulty relay but I don't know which to look at / ring out. Could it be the Main Engine Relay? EFI? How would I go about checking the ECU on this car? Thanks guys! |
Chockomon '95 5S-FE Randomly Shutting Off Nov 18, 2010 - 6:07 PM
Smaay might be the fuel pump relay, or the pump itself. Nov 18, 2010 - 6:09 PM
Remy Jump the terminals (T1,E1) to see if any codes are... Nov 18, 2010 - 6:14 PM
JuMPiiN My Celi does the same thing, I was told by a few p... Nov 18, 2010 - 6:16 PM
Chockomon So if the distributor is bad, the CEL may not ligh... Nov 18, 2010 - 7:46 PM
supercoolee my celica has the same problem a lot of people tol... Nov 18, 2010 - 8:40 PM
Chockomon hey guys, I figured I'd make it a little clear... Nov 19, 2010 - 7:32 AM
presure2 i know this seems like a stupid question, but are ... Nov 19, 2010 - 9:09 AM
Chockomon Battery terminals are clean, battery was recently ... Nov 19, 2010 - 9:25 AM
Smaay well the cranking thing leads me to bad starter ci... Nov 19, 2010 - 12:02 PM
JuMPiiN This is whats wrong with my Celica, It starts up p... Nov 19, 2010 - 5:38 PM
SleekCelica It is the ECU, and trust me. I've been through... Nov 19, 2010 - 8:35 PM
presure2 bridge fp and b+ in the daignostics box and see if... Nov 21, 2010 - 8:46 PM
Chockomon So I printed out some wiring diagrams and I'm ... Nov 22, 2010 - 8:43 AM
presure2 QUOTE (Chockomon @ Nov 22, 2010 - 8... Nov 22, 2010 - 9:35 AM
Smaay ^^^ yes it basically turns your fuel pump on all t... Nov 22, 2010 - 10:59 AM
Chockomon Ok update. Car shut off when driving after hitting... Nov 24, 2010 - 5:39 PM
njccmd2002 http://www.toymods.org.au/forums/showthread.php?t=... Nov 25, 2010 - 12:59 AM
Chockomon So I got it fixed! Turns out the fuse for AM2 ... Nov 25, 2010 - 3:39 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 22nd, 2026 - 8:12 PM |
