> my head lights turn off and on while im driving why?, as tittle says....
post Nov 19, 2010 - 9:31 PM
diegohiga
Joined May 4, '09
From coral springs florida US
ok im driving and it turns off and on... idk why.. i got a new battery so battery is good.... it doesnt happen all the time but sometimes it does... battery cables are tight... so i dont know what is causing that... could be the altenator?
post Nov 19, 2010 - 10:51 PM
azian_advanced
Joined Apr 18, '05
From Calgary
if they're flickering on and off, your HIDs could be on their way out.
if they're just dimming and getting brighter on and off, then your alternator is probably on its way out
post Nov 19, 2010 - 11:20 PM
diegohiga
Joined May 4, '09
QUOTE (azian_advanced @ Nov 19, 2010 - 10:51 PM) *
i dont think could be the hids cause both do the same at the same time.. sometimes they just turn off and i have to turn off my switch and then turn it on again... sometimes they just go off and then on again... im guessing altelnator??
oh! and sometime my battery light turn on and then go off.. when that happens the hids start going bad. but like i said i bought the battery about 3 month ago...
post Nov 19, 2010 - 11:44 PM
mkernz22
Joined May 10, '10
From MA
it's probably your alternator
it's highly unlikely that the ballast could be messed up, right?
post Nov 20, 2010 - 1:29 AM
6gc_ct
Joined Apr 5, '10
From conneticut
I had only one side of my lighting do this, where i would be driving and it would go off and on quickly as if you blinked. i have 8k HIDs. Turned out to be a bad bulb, i found some new ones on amazon and ive been good from there on out. Luckly i was able to determine bulb from ballast because it was only one side. Both sides would be tough. However i did notice that the bad bulb had a cloudy look inside where the little "bubble" is, new bulb is clear. Hope this helps.
post Nov 22, 2010 - 4:11 PM
captb
Joined Sep 23, '08
From Hawaii
did you do the big three upgrade yet?
post Nov 22, 2010 - 9:21 PM
diegohiga
Joined May 4, '09
QUOTE (captb @ Nov 22, 2010 - 4:11 PM) *
big three upgrade?
post Nov 22, 2010 - 10:15 PM
captb
Joined Sep 23, '08
From Hawaii
QUOTE (diegohiga @ Nov 22, 2010 - 4:21 PM) *
big three upgrade?
toyota decided to give us small gauge wires for our electrical components just enough for the necessities. when you upgrade audio, HID, etc. you should increase the size of the 3 grounding wires. I did it when i installed subwoofers and problem went away.
http://www.the12volt.com/installbay/forum_...~TID~73496~PN~1
post Nov 22, 2010 - 11:16 PM
block
Joined Jul 27, '06
From Soda
it's time to change your bulbs. i had this happen on my celica with the jdm headlights and ended up changing the driver's side bulb. also had this happen on my is300 where it kept flickering, changed the bulbs and works great now.
Lo-Fi Version Time is now: August 23rd, 2026 - 7:07 AM
