> * Please Help: Cigarette Lighter *, Cig Lighter Not Working
post Nov 23, 2010 - 6:53 PM
phob0z
Joined Apr 19, '10
From PA
Alright. My Cig lighter has always worked, whether it was to heat the actual Cig lighter piece, or to charge a phone, plug in and power a GPS, etc. Last week I bought a little heater that was designed for cars, made by Peak. Had the heater plugged in, and it worked for about 5 minutes or so, and then off. Ever since then, the Cig lighter hasn't worked at all, no power.
Now, I checked the fuse that powers both Radio/Cig lighter.. the radio still works with fuse in, with the fuse out radio doesn't work. So with that I'm assuming it can't be the fuse because while the fuse is in it's still powering the radio.
Any ideas what my next step is to get my Cig lighter working again? Need to use my GPS.. frown.gif
Also, I pulled out the Cig lighter and all the wires are still in place and in tact.
Replies (1 - 10)
post Nov 23, 2010 - 8:17 PM
brk34
Joined Jan 20, '08
Check the manual to ensure that you have checked the proper fuse. Next check for voltage at the terminals that power the cigarette lighter. In my car the lighter was not working, it may have been corroded or an internal fault. I simply replaced it with a accessory socket from radio shack. Maybe you overheated the socket by drawing too much current causing it to fail.
post Nov 23, 2010 - 8:38 PM
phob0z
Joined Apr 19, '10
From PA
I think I overheated it. If that's the case then..?
post Nov 23, 2010 - 9:39 PM
brk34
Joined Jan 20, '08
Buy a new one.
post Nov 23, 2010 - 10:06 PM
phob0z
Joined Apr 19, '10
From PA
A new socket? How universal are the connections to make sure it can be wired?
SupraKid
Joined Aug 15, '10
From The Best Coast
Get a multimeter and check if there is power in the wires behind the actual unit.
post Nov 24, 2010 - 1:06 AM
pyeatts
Joined Jun 9, '09
From Saint Louis
There’s a hard soldered limiter on the back of the cigarette lighter socket. When it overloads it blows and has to be replaced. You’ll see it soldered to the power line on the back of the socket when you pull it out. You can solder in a heaver limiter if you want to run higher amp accessories, but I chose to install a high load accessories socket just for accessories. Now there are much better looking ones available at auto parts stores. I put this in years ago. Takes about twenty minutes to wire up.
post Nov 24, 2010 - 9:05 AM
phob0z
Joined Apr 19, '10
From PA
I see.. thanks for the info. I think what I may do for now is just try and get a replacement socket and leave it at that. Assuming I have no other issues. And I'm assuming/hoping its a matter of pulling the old one out and plugging the new one in.
post Nov 24, 2010 - 9:16 PM
brk34
Joined Jan 20, '08
I think the cigarette lighter uses standard spade correctors.
post Dec 15, 2010 - 12:12 AM
eboz74
Joined Dec 14, '10
From Lansing MI
the same thing happened to me before but it was just the fuse
post Dec 15, 2010 - 1:15 PM
phob0z
Joined Apr 19, '10
From PA
QUOTE (eboz74 @ Dec 15, 2010 - 12:12 AM) *
Yeah, in my case, not the case, lol. I think the socket burnt out / sparked and shorted when the portable heater was plugged in.
Lo-Fi Version Time is now: July 6th, 2026 - 12:55 AM
