Nov 30, 2010 - 5:37 AM
Enthusiast Joined Oct 24, '10 Currently Offline Reputation: 0 (0%) |
I'm about to change the engine oil on my 1.8 7A-FE. What kind of oil should I use? As mentioned in the topic title the car have driven 142K miles, or 226K Km.
On Castrols website I used their oil guide (http://ew5.earlweb.com/recommendations.php?site=71§or=1&category=6&subset=278&modelyear=&vehicle=7964), and it says that I should use 5W/40, but since the engine isn't new I have heard someone say that 10W/40 is better? Btw it's winter here in Denmark (Scandinavia) right now it's around -10 Celcius, and it is probably getting worse. Which oil should I get? This post has been edited by Gamebitz: Nov 30, 2010 - 5:39 AM |
Nov 30, 2010 - 11:04 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
in my opinion i would use the 5w, just because of the cold. when you start your car when its cold with a heavy wheight oil, its hard on your engine because the oil is cold and has no viscosity( or doesnt want to flow). my car has 350,000 miles on it and in the summer i use 10w 30 and the winter 5w 30. not once have i had a probleme yet.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Nov 30, 2010 - 11:17 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
in my opinion i would use the 5w, just because of the cold. when you start your car when its cold with a heavy wheight oil, its hard on your engine because the oil is cold and has no viscosity( or doesnt want to flow). my car has 350,000 miles on it and in the summer i use 10w 30 and the winter 5w 30. not once have i had a probleme yet. Do you still have the original engine in it? |
Nov 30, 2010 - 11:27 AM
yea, runs like a champ/ i wish i could thank the builder of my engine personally.
Nov 30, 2010 - 11:31 AM
Nov 30, 2010 - 11:39 AM
so far i havent found anyone that has more than me witht the original motor. but im going to drive it till its last breath, and then do a swap.
Nov 30, 2010 - 11:52 AM
I'm thinking about swapping mine out in the spring when I do my manual swap, but I'm not exactly sure. It burns a little bit of oil when i floor it, but it's not that bad at all. Still runs strong at 218k, but I'm just iffy cause I'm going to college next year and I'll be doing a lot of traveling my next 4 years.
On topic though, definitely go with the 5w if it is that cold. It will be better when you're first starting her up |
Dec 2, 2010 - 10:27 PM
Enthusiast ![]() ![]() ![]() Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) |
cold weather and a heavy weight oil is bad news my friend. when your car sits for a long period of time (like wen u wake up from sleeping) and go to start your car, keep in mind all your oil drains to the pan no matter what oil. heavier oil takes longer to work its way thru the motor and thinner oil is faster when you start your car.
-------------------- ![]() those with golf balls golf those with real balls race |
Dec 11, 2010 - 2:51 PM
I think I'm gonna go with 5/40W since it's winter but I found out that it runs with 5/40W now, but since that oil was put in it uses alot more. So it's going to be 10/40W when it's summer I think.
| Lo-Fi Version | Time is now: August 22nd, 2026 - 7:25 PM |
