Dec 7, 2010 - 2:47 PM
Enthusiast ![]() Joined Jan 11, '07 From carmel, new york Currently Offline Reputation: 7 (100%) |
Hey Guys and Gals
My name is Art, I've been a member of the community for about three years. I am a steamfitter by trade and was thinking of fabbing my own strut tower braces I am certified to weld under nuclear conditions with an X-ray test to determine the efficacy of my welds, both of the stick and MIG processes. I was wondering if there was any interest out there for me to fab these braces for more than myself. I 'm not entirely sure of the materials yet, the easiest to get a hold of and join would be steel. I realize that is probably heavier than most of you would want, First mock up picture, Made this to check fitment for the steel jig I made from the wooden one that I made with Stevenson, from his Jspeed one. This one is 3/4 schedule 40 steel pipe It's fit into my trunk right now, to make sure the fitment is correct. I have a couple of tweaks to make. But the rears are going into production tomorrow 12/16/10.Front brace mock up for jig, fitment is good just have a couple of clearances to check ![]() had to make the front support just about from scratch,didn't turn out too bad if you ask me though.
This post has been edited by Darkchylde: Dec 18, 2010 - 1:22 AM |
Dec 7, 2010 - 3:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
I'd be interested in a rear one
Dec 7, 2010 - 3:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
just so everyone knows, I've seen his welding skills first hand and is superb,
Art, if you want we can meet up and you can take measurements and stuff out of both of my strut braces ( front and rear ) they are J-speed braces made out of alluminum, and they clear the top mount intercooler which will be a concern for most 3rd gen swappers. -------------------- ![]() |
Dec 7, 2010 - 6:01 PM
excellent idea Stevenson, I might need to remove the front one to get the clearance height correct off of a flat surface. If that wouldn't be to much trouble, and thanks for the good word.
Dec 7, 2010 - 6:04 PM
I was also just informed that the bottom mounting position between 94-96 and 97 and up are different so if anyone knows the measurements for a 97 send them my way. (that would be the bottom position on the rear 3 point.)
This post has been edited by Darkchylde: Dec 11, 2010 - 12:31 AM |
Dec 7, 2010 - 6:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
If you can pull out a decent front three point, count me in if you throw in the NDI as part of the deals!
Dec 7, 2010 - 7:29 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
I'm down if its 150
Dec 7, 2010 - 7:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
3 point Strut for the hatchback REAR please! i will definitely buy
Dec 7, 2010 - 11:58 PM
Enthusiast ![]() Joined Jun 3, '09 From North Dallas Currently Offline Reputation: 1 (100%) |
I would need all three plzz.
Dec 8, 2010 - 12:57 AM
are you limited to just the strut or can you do other parts like roll cages...or sway bars...long stretch but i thought i ask.
Dec 8, 2010 - 3:21 AM
Enthusiast ![]() ![]() ![]() Joined Sep 23, '08 From Hawaii Currently Offline Reputation: 10 (100%) |
Dec 8, 2010 - 5:42 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
harness bar!
Dec 8, 2010 - 12:29 PM
chacha, not sure about the roll cage, i would need to get quitea few specs. I' will check it out though. the Harness bar is def. a possibility like I said though this is a feeler I have tocheck on some material options. the rear strut brace is no problem, because it is small i can just use schedule 40 steel piping. Same for the harness bar. The front brace and roll cage components are all much larger, so I have to either order thinner wall piping or get another lighter material such as aluminum, The shop I work for does havean account with a piping and fab metal distributor, but the juice kinda has to be worth the squeeze you know what I mean. If I can get the metals at a decent price as well as the supplies for joining said alternate metals than no problem. I also would need some very detailed specs for the roll cage. Or pre made plans and or measurements from an exisisting set. Then there is the cost of shipping. trying to ship a full cage is probably going to pretty pricey, but shipping just the peices leaves a bit of work to be done for the purchaser. I'll do some research, and if those of you interested in cages try to find some info as well, that would be greatly appreciated. From the looks of it though I will be making at least the two strut braces and the harness bars at the moment. Steel will be the material at the moment but if I can get the aluminum and the wire for the weling at a decent price then they will be a composite. Steel brackets and aluminum bars.
On another note I wanted to know if you guys would rather see them Solid or Adjustable? As far as the sway bar goes I beleive those are a sprung or twisted type of metal that have a load placed on them for tension of a sort. If I am wrong then someone please correct me. But for the mean time I'm going to have to give that one A big nno for safety sake. Sorry. This post has been edited by Darkchylde: Dec 8, 2010 - 12:36 PM |
Dec 8, 2010 - 3:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
If its aluminum and anything like the Jspeed i am definitely interested
Dec 8, 2010 - 6:55 PM
Enthusiast Joined Nov 3, '10 From maine Currently Offline Reputation: 0 (0%) |
-------------------- i want a F!@#$% GT4!!
Dec 8, 2010 - 10:50 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
but also 3pt front and rear. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Dec 9, 2010 - 2:00 AM
will be in need of a harness bar (planning on getting a reclinable bucket seat)
Dec 9, 2010 - 4:09 AM
Well guys here is the deal on the harness bars. If you need them I will need certain information from you. There are more peices to be made than just the one bar, you need one for the shoulder straps, one for the crotch belt and one for each of the hip belts. Sooo.... the cost has yet to be determined I will try to be very fair and I'll have some kind of draft and price within the week.
Back to a previous question I need to know if you all want any of theses braces to be of the adjustable type, so that I can have a better idea of the specific hardware needed for the build. Adjustable: http://www.japperformanceparts.co.uk/pdeta...sp?ID=100866748 Solid: http://image.importtuner.com/f/10242775+w7...strut_tower.jpg The adjustable option will only be entertained for the front brace only, and that is only if I get enough responses for it. All rear braces will be solid. Personally I prefer the solid look anyway. Oh and do any of you have an interest in a camera mount on said harness bar? This post has been edited by Darkchylde: Dec 9, 2010 - 4:22 AM |
Dec 9, 2010 - 5:59 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
I rekon a solid option is much better.
And im definately keen on a camera mount but not on a harness bar. Maybe mounts through the passanger headrest and pokes out to the centre. Like whats his name did it 3-4 years ago. -------------------- |
Dec 9, 2010 - 8:50 AM
solid 3pt front and rear, not adjustable. aluminum if possible.
| Lo-Fi Version | Time is now: September 11th, 2026 - 3:44 PM |
