> 7A-FE Engine
post Dec 9, 2010 - 3:42 PM
SCPOW
Joined Dec 9, '10
From SC
Hey guys,
I'm new here and wanted to get something straight. Are the 7A-FE motors from 90's Corolla the same as the 7A-FE in the Celica's? I have a 97' ST Celica that threw a rod bearing and I'm looking for a replacement engine. Would it be safer to buy a OBDII 7A-FE from another Celica or would a 94-95 Corolla motor do?
If a Corolla motor will do, what are some of the things I would need to use from the Celica 7A-FE to work with the 7A-FE in the Corolla motor?
Any info would be appreciate. Thanks!
post Dec 9, 2010 - 3:48 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
a 94/95 Corolla motor would be too much trouble since it's OBDI
June '12 COTM
'95 AT200
post Dec 9, 2010 - 4:00 PM
SCPOW
Joined Dec 9, '10
From SC
QUOTE (HectortheRican @ Dec 9, 2010 - 4:48 PM) *
Okay, when did the Corolla's go to OBDII? 97? And would a 7A-FE out of that year be easier to swap into the Celica?
On another note, I can't seem to find any 7A-FE motors from 97's, I've only found a few out of 96's, are they the same as 97's 7A-FE's aka OBDII?
This post has been edited by SCPOW: Dec 9, 2010 - 4:07 PM
post Dec 9, 2010 - 4:21 PM
HectortheRican
Joined Dec 26, '09
QUOTE (SCPOW @ Dec 9, 2010 - 4:00 PM) *
Yeah, anything '96 and after is OBDII. That's when the change was made. and the Corolla with the 7A in America was the AE102, from 93-97
June '12 COTM
'95 AT200
post Dec 9, 2010 - 6:40 PM
SCPOW
Joined Dec 9, '10
From SC
QUOTE (HectortheRican @ Dec 9, 2010 - 5:21 PM) *
So a 96' 7A-FE out of a Corolla or a Celica would simply drop right back into my 97' Celica?
Anyone with any suggestions?
post Dec 10, 2010 - 6:22 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
The OBD1 would also work with minor mods basically you will swap the Intake manifold from yours to the new engine
2001 Solar yellow Lexus IS300
post Dec 10, 2010 - 6:30 PM
NOVAKx17
Joined Oct 7, '09
check out my thread, its in the exterior styling portion of the site, i went through the same thing basically
i am putting in a 94 celica st engine into a 97 shell.. its almost done, and i put up all the problems and changes i had to go through... good luck either way!
NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold
1997 Celica ST- swapped and sold
2004 Ford explorer xlt 4x4- totaled
1997 Celica Convertible GT- Going Topless (;
(18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi
( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 )
post Dec 10, 2010 - 11:53 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
there is bad info here, sure the year went to ODBII but that doesnt matter. the OP threw a rod, thats the bottem end! any and i mean ANY 7A bottom end will work just fine for you. all you ahve to do is put your head, manifolds, and accessories on it. sometimes you might get away with long block swapping just using your electronics.
Get out of the box, there is always an option
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Dec 11, 2010 - 1:30 AM
SCPOW
Joined Dec 9, '10
From SC
I have no knowledge of putting a motor together so that's why I choose to just buy another 7A-FE motor and drop it back in.
Question here is which motor would be easiest to drop in? I can't seem to find any 97' 7A-FE, is a 96' the same?
And 96st, what other minor mods would I need to make a older OBDI motor work?
post Dec 11, 2010 - 9:39 AM
wow. lots of misinformation here.
you can use just about any 7afe you want, keeping these things in mind.
if your car is 96+, like yours is, and you use a replacement out of an earlier year, you will have to use the following parts off your current motor.
intake (with throttle body) and exhuast manifolds
coolant waterneck
crank position sensor, oil pump housing, and crank pully with intergrated trigger wheel for the crank position sensor
possibly fuel rail and injectors (but thats more a 5sfe thing)
harness and ecu
thats the short list.
basicly anything on the motor that has a sensor, your gonna wanna check against what you have, and make sure they are the same. if not, use the part off the old motor.
post Dec 11, 2010 - 11:54 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^ exactly, usually when you buy a used engine, you only get the longblock, no manifolds. so you will have to just transfer your stuff over. its not assembling the engine, just the sensors and manifolds.
post Dec 13, 2010 - 6:18 PM
SCPOW
Joined Dec 9, '10
From SC
QUOTE (presure2 @ Dec 11, 2010 - 9:39 AM) *
coolant waterneck
harness and ecu
That sounds like a lot to swap over. I'm a Nissan guy and when I dropped a earlier motor year 93' into my 97' chassis, I swapped distributor and intake manifold and ta da that was it. Is all that stuff listed above just SOME of the items I have to swap over? That sounds like a lot of stuff. =\
post Dec 14, 2010 - 12:51 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
not sure how you got away with that since you put an ODBI engine in an ODBII car
post Dec 14, 2010 - 3:44 AM
SCPOW
Joined Dec 9, '10
From SC
QUOTE (Smaay @ Dec 14, 2010 - 1:51 AM) *
Does anyone have a list of what is all needed from an OBDII engine to make a OBDI engine work in a OBDII chassis?
Someone said I should search and trust me, I searched before I joined the forums but I had no luck.
post Dec 14, 2010 - 1:48 PM
mkernz22
Joined May 10, '10
From MA
Pretty much, you just have to take everything off your '97 block, then put it all on the new block you get.
post Apr 4, 2011 - 12:53 PM
vagina
Joined Apr 1, '11
I'm looking to do a swap. The donor car being a 1996 Corolla 7afe. The car it will be going into is a 1996 Celica that already has the same 7afe. I haven't looked too much at the coroll but i did notice the map sensor is a bit smaller and different, other than that things look the same. I get work release from jail everyday so i'm lookin to get this all done in 1-2 days. I've done a few engine swaps and builds so i'm wondering what problems i'm going to have that anyone knows of before i start at it? I know i could play around and take my time and read an fsm on both but kinda short on time. Thanks
post Apr 4, 2011 - 3:21 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (vagina @ Apr 4, 2011 - 12:53 PM) *
Did they teach you to read as well?
Cause...yea..scroll up.
post Apr 4, 2011 - 3:46 PM
HectortheRican
Joined Dec 26, '09
QUOTE (rave2n @ Apr 4, 2011 - 2:21 PM) *
Aww don't be so harsh
June '12 COTM
'95 AT200
post Apr 4, 2011 - 3:49 PM
rave2n
Joined May 29, '09
QUOTE (HectortheRican @ Apr 4, 2011 - 4:46 PM) *
Lol, i'm usally not. Tend to be quite peaceful.
Dudes name is "Vagina" though, then asked the same damn question as the original post. Hard to respond serious to that =P
post Apr 4, 2011 - 5:12 PM
vagina
Joined Apr 1, '11
Read? What's that? And where in the earlier posts does is state the complications, if any, of doing an obd II 7afe into another obd II 7afe? Please enlighten me smile.gif And going from the same chassis is an obvious given that everything should work (depending on year), But i'm looking at an engine coming out of a corolla and going into a celica. Just in case some of you forgot or can't read earlier posts smile.gif
Edit. So to ask question into simple terms... What differences are there between the obd II 7afe in a 1996 toyota corolla vs. an obd II 7afe in a 1996 toyota celica? I noticed the map sensor is different. What problems would I have with that? Can i just use my map sensor? I think I can but I know there someone on here that's done this a time or two that has some pretty useful info that'll help alot. Thanks.
This post has been edited by vagina: Apr 4, 2011 - 5:18 PM
Lo-Fi Version Time is now: August 30th, 2026 - 11:04 PM
