> Want To Install HID Fog Lights?, Look Here
post Dec 14, 2010 - 12:25 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
After being asked by a few people i thought i would lend a hand and give you all a detailed write up on how to install HID Bulbs in your OEM foglights, Now i did this in a facelift with the wires already run from the factory. Orginaly for the standard bulbs i just used the oem wiring for them and put the switch in, but you will not get enough power from this to power HID bulbs, one will work but not the other, it is not your wiring it is the lack of power. If you want something fast and easy then this is not for you, if you want quality work and lights that will last do it this way and do not cut corners.
You will need a few supplies for this:
This is the Relay, be sure that you follow directions on how to use this
Soldering Iorn
Electrical solder
Butane torch
16 Gauge Wire
Heat Shrink Tubing
Wire Strippers
Toggle Switch
Female and Male Blade Crimp Adapters
Zipties
Double Sided 3M Heavy Duty Tape
Coat Hanger
Now what you will do is Run one wire off the relay to a approprate ground, run one straight to the battery, the other wire goes to a power source of your choosing, you will put the switch in this line, run it off any ac wire that has a current running to it (this is going to draw very little current, just enough to open the relay) the last blade on the relay will actually run to the power wire on the ballast. You will basically piggyback the power from the relay to both ballasts, along again with your ground of choice. make sure that every place you have to put any wires together you solder the connection and then shrink wrap it so no water will get in there and the wires will not arch, this will kill your relay if they arch. I will try and take pictures when i can and further update this, but if you need help feel free to pm me
2001 Solar yellow Lexus IS300
Lo-Fi Version Time is now: July 6th, 2026 - 7:02 AM
