Dec 14, 2010 - 9:53 PM
Enthusiast ![]() ![]() Joined Dec 14, '10 From Lansing MI Currently Offline Reputation: 1 (100%) |
I'm new to toyota motors and basically motors in general but i need to clean my valve cover and before i mess anything up can someone explain how to get it off i know you need to take out the spark plug wires but i cant find the bolts lol dumb i know but will someone explain the process
Dec 14, 2010 - 9:58 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
the round area (the part your plugs go down in) is actually what holds the valve cover down. when you take your wires off, the top isnt all the way round, there should be 2 flat side so you can loosen them up. i will look for a picture to help you out.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Dec 14, 2010 - 10:02 PM
also will i have to replace any gaskets?
Dec 14, 2010 - 10:04 PM
im not sure, i know you will need a type of sealent or something, i cant remember the name off hand.
Dec 14, 2010 - 10:07 PM
oh ok thank you i am also thinking about painting it
Dec 14, 2010 - 10:10 PM
high temp paint for sure! i have been told to always replace the valve cover gasket after doing work on it.
Dec 14, 2010 - 10:12 PM
anytime!
Dec 14, 2010 - 11:12 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
Don't use a crescent wrench. It should be a 30mm socket.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Dec 14, 2010 - 11:17 PM
okay
Jan 4, 2011 - 10:37 PM
Enthusiast Joined Sep 12, '10 From Waukesha, WI Currently Offline Reputation: 0 (0%) |
Jan 5, 2011 - 1:44 PM
yes its a 30MM socket. and if you ahve never done it before, you should replace the gasket. the sealant mentioned above is called FIPG and you only need a tiny bit. its very expensive for a tube of it so you might skip it. its not going to hurt you if you dont use it
| Lo-Fi Version | Time is now: August 29th, 2026 - 1:41 AM |
