Sep 19, 2018 - 9:26 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Well I haven’t updated this in a hot minute. Intake manifold is here. We’re just waiting to put it on. We slapped a manual boost controller on in the meantime and set it to 11psi. I’ve been getting about 24 - 26 MPG with it, and I’ve been beating it like it owes me money.
The TCS coolant neck broke on like the 4th or 5th day. The overflow port broke off, which is when I learned that TCS just epoxied it in place. I replaced it with a RacerX unit. We should be ready to slap the intake manifold on in a few weeks, and then it’s back to the tuner for the final tuning and max power pulls. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Sep 22, 2018 - 5:42 AM
Enthusiast Joined Sep 18, '18 From California Currently Offline Reputation: 0 (0%) |
Long time ago I was a vendor for MR2OC making carbon fiber part's for the masses. But I got like half of them saying that part's should be carbon fiber from the inside too. So I decided not to make any aftermarket part for MR2. Okay now on for the story on here. I thought those 1MZ engine would mate up to a 3S-GE manual transmission with no problem. People say that the 1MZ can't mate with a 3S-GE automatic transmission. The entire thing is suppose to keep cost down and not let people on a wild goose chase finding a transmission.
Sep 27, 2018 - 9:20 AM
I had to run to get some SD cards for work yesterday, and on my way back to the office I noticed the temp gauge rapidly climbing. I quickly pulled into the next parking lot and shut the car off. I could hear hissing from the engine bay.
![]() It looked like the lower coolant hose had ruptured, so I had to call AAA to come get me and take me home. Once I got the car in my garage I got to work. This is what I found: ![]() I must’ve knicked the hose when I put the heat shield back in, and it finally popped. New hose will be here today, and I have to go drop a small fortune on coolant at the dealership. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Sep 27, 2018 - 6:55 PM
On the positive side you caught it before it caused any serious damage.
Sep 29, 2018 - 10:19 AM
Yikes, the way it's cut across the webbing almost looks intentional!
Nov 7, 2019 - 9:29 PM
Well I've been away for a minute...
MR2 is still a work in progress. A victim of the oft-moved goalposts, I've kept tinkering with different aspects, but never coming back to the engine work to complete it. So, engine bay update: ![]() I pulled out the TCS coolant overflow tank in favor of a matching Racer X piece. I also finally got my hands on some M10 stainless hardware so I was able to replace the bolts that connect the X brace to the firewall with something that doesn't rust. I had been looking at the brakes, which got my OCD going. The rears were upgraded to the 93+ Turbo rear brakes, and are larger than the front non-turbo brakes. The car looked goofy. I had to fix it, so I upgraded the fronts to Wilwood 4 pot superlites with MKIV Supra Turbo rotors. Just barely cleared the back of the valve stems. ![]() ![]() ![]() Recently I got to thinking that pretty much the only things that are still stock on the 3S was the valvetrain. I knew I wanted to upgrade the cams eventually, so I bit the bullet and ordered a set of GSC S1 cams (268 degree), GSC valve springs and retainers, and a pair of ATS cam gears. These are going to be going in along with the intake manifold hopefully in the coming weeks so that I can get the car back to my tuner for a final tune. ![]() ![]() In a less "big" change, a couple weeks ago I swapped the rear tires for 255/35-R18's and got rid of the 245's. Looks much better now, but I don't have a picture of this. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Nov 7, 2019 - 9:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
I did that exact same valve train set-up in mine except I added shimless buckets with'em. I can't wait to hear how it sounds! I'm jealous of those carbon intercooler pipes though. I'm thinking about doing a titanium piece for mine later on down the road. I dunno what you're running for fuel, but I'll have my MK4 550cc injectors up for grabs soon if you're interested. They were cleaned and flow tested before I put them in, but decided to go bigger with 1000cc injectors and E85.
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Nov 7, 2019 - 10:02 PM
I did that exact same valve train set-up in mine except I added shimless buckets with'em. I can't wait to hear how it sounds! I'm jealous of those carbon intercooler pipes though. I'm thinking about doing a titanium piece for mine later on down the road. I dunno what you're running for fuel, but I'll have my MK4 550cc injectors up for grabs soon if you're interested. They were cleaned and flow tested before I put them in, but decided to go bigger with 1000cc injectors and E85. ID1050X's in a Racer X rail, full -6 lines to the pump. E85 in the Seattle area is pretty much impossible to find. There are 7 stations in the state that sell it. It isn't like the corn belt states over here, HOWEVER my tuner wants to slap a flex fuel sensor on it just so we can see what it'll do with E85, but meh. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Nov 8, 2019 - 10:41 AM
oh nice! Went similar with FID1000s. Walbro 450 with -6AN lines up to the rail using an in-line Radium Engineering filter.
Doesn't hurt to see what you'll make on corn juice. I'm hoping to hit a solid 350hp or at least to see whatever the limit is on the S54 transmission as far as torque is concerned. lol What are you planning to tune with? I'm hoping to pick up a Link G4 PnP ECU this weekend. -------------------- -Alex {](O_o)[}
Nov 8, 2019 - 12:32 PM
That is what I have. MR2Link v3.
Nov 13, 2019 - 8:22 PM
are the injectors that you received 11mm or 14mm? RacerX is telling me their rail is for 14mm injectors, but my FIDs aren't fitting the rails.
Nov 14, 2019 - 10:38 PM
1050.60.14.14.4 was the part number for mine, so 14mm injectors. Popped right into my Racer X rail.
Put up some pics of your situation. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
| Lo-Fi Version | Time is now: August 21st, 2026 - 2:04 AM |
